Is stupid... Only stupid at this price inadmissibleRegarding the volume cap:
Even if the volume can be turned up after the warning, there should still be a volume limit, as in a non-EU player should sound louder at maximum volume when compared to an EU one.
Sony Walkman Thread: 2022 Successors to the WM1A & WM1Z
Mildly sluggish, swapping between apps is a bit slowThoughts on UI performance?
MrWalkman
Sounds like the experience on a ZX500/A100, sadly. Snapdragon 660 that I see it's being used on certain new DAPs should be much better.
And thats why I just went and bought the last WM1Z in Sony stores in Singapore. Sound wise both the WM1Z and WM1ZM2 are really close but the new one is just more layered and positioning is better.Sounds like the experience on a ZX500/A100, sadly. Snapdragon 660 that I see it's being used on certain new DAPs should be much better.
rcoleman1
Happily keeping my W1MZ Blackgate mod. I'll watch the reviews and pick up a WM1AM2 next year.
MrWalkman
I wonder how big is the difference in layering/positioning, for example, on the new WM1Z vs a hardware modded WM1Z (or a hardware modded WM1A with the WM1Z sound signature, from the Walkman One firmware).
Hardware mods for 1A/1Z can include an additional supercap, and Audio Note caps for the amping/power supply side.
siruspan
- Sep 11, 2010
To be honest this releases look on paper kinda underwhelming. After 6 years I was expecting all new design inside and out and they are wm1a/z with added android with only minor changes.
Yay! Congratulation!!And thats why I just went and bought the last WM1Z in Sony stores in Singapore. Sound wise both the WM1Z and WM1ZM2 are really close but the new one is just more layered and positioning is better.
MrWalkman
We should see more people's thoughts about the sound soon, I guess.
I like the Type C connector for now, and how the players look overall. I don't like the missing BT Receiver function. Maybe they'll add it later. They added BT Receiver and USB DAC modes after some time on the 1A/Z.
Thanks hoofman! Maybe we might bump into each other at canjam this year!Yay! Congratulation!!
I'm sorry if my description of the sound is a bit sparse but I was most taken aback by the feel in the hand than anything else. I wanted that feel but not for 5000SGD so I went with the old WM1ZI wonder how big is the difference in layering/positioning, for example, on the new WM1Z vs a hardware modded WM1Z (or a hardware modded WM1A with the WM1Z sound signature, from the Walkman One firmware).
Uhm? This is exactly what it is.To be honest this releases look on paper kinda underwhelming. After 6 years I was expecting all new design inside and out and they are wm1a/z with added android with only minor changes.
The old WM1Z used an 500mF double layer capacitor, 1 OS-CON and 13 FTCAP. So 14 Wound Capacitors and 1 Double Layer.
The new WM1Z uses 20 FTCAP3 (the first and only device that uses this new developed capacitor which is the core of the Sony sound) in different sizes and in a different configuration than before and in a different board layout. So 20 wound capacitors vs 14, one of them replacing the double layer and a new version of the S-Master HX
The LCs and relayes stayed the same, yes, but there is pretty much no room for improvement there anyway. 8mm is already the limit for an device of this size.
They put a newer version of the Digital Amp in and replaced pretty much all capacitors inside the device + added new ones and also replaced everything in the digital part, the screen and so on. There is literally nothing more you can change, they replaced almost everything that was inside the WM1Z.
MrWalkman
In any case, I don't see the sound difference between two players like these being all about the copper enclosure vs aluminium and different wires.
I understand that the better caps in the classic WM1Z provide an edge over a WM1A with the WM1Z sound, but these new players are using the same components on the main PCB.
But all this is a different topic of discussion.
nc8000
Don't blame Sony for actually playing by the rules (as opposed to all the China makers as far as I'm aware), blame EU for making the ruleIs stupid... Only stupid at this price inadmissible
did we get upgrade only for walkman or for Z1R headphones as well?
That is what Sony says too.In any case, I don't see the sound difference between two players like these being all about the copper enclosure vs aluminium and different wires.
According to the Project Members, the difference between the WM1ZM2 and WM1AM2 is much smaller than the difference between WM1Z and WM1A. And also they no longer differ in sound signature.
The WM1A and WM1Z had not just a difference in sound quality but small differences in sound signature too. This no longer exists with the M2, they have the exact same tuning/sound signature.
According to their description, there is only a marginal difference in sound stage and clarity due to the lower/flatter impedance of the copper chassy.
So i think while with the current model there was an advantage when buying an WM1Z, for most people that is gone. I'd assume that the majority of listeners would not be able to pick them apart in a blind test. So its a matter of how much are you willing to pay for the last quantum of sound.
