Some people still seems like they had the issue with installing DMP-WM1. I updated the installers yet again, hopefully all is good for everyone this time.
Just installed it on my WM1A and tried it with a IER-Z1R .... difficult to say, but I was already really pleased with the Z++ .. for sure it's not worse with this DMP version and probably again a step better.
So, I will keep using the DMP-WM1 for a while and I will give a try next week to my WM1A + TA-N55ES + Heddphone and Z7M2 (connected through 3.5mm SE output) .. and see what happens.
But already, cheers !!! and have again some fresh beers.
Regarding the mod, my opinion is that it's better than the + and ++ mods, and even better than CHAMELEON 2.0 (which brings the wider soundstage of the 1Z, etc.).
That ice cream is tedious due to the need to overwrite zips.http://jump2.bdimg.com/home/main?un=ck1983426928&ie=utf-8&id=tb.1.47c0d129.LtuHJoJZYG3Trh6_kKj6Yg&fr=pb&ie=utf-8
That was August, now it's October, what do you mean by 'Sony will be knocking real soon'? Anyway, this is a win-win through and through. There's nowhere to knock on.
Just want to report some slight USB DAC problem. The video and audio is out of sync by let's say 0.5 seconds. LDAC Bluetooth on the highest setting is not stable, but on the lower setting works just fine.
