Nice,thank you!!I ended up to buy the DAs R10 and TA ER1These settings Rock!!
It's been years after allNice,thank you!!I ended up to buy the DAs R10 and TA ER1![]()
For my WM1A test the closest to the DMV the settings were as follow.@MrWalkman which region and sound profile for WM1Z is the closest mimic of DMP-1Z?
The profile/signature should be the Bright one@MrWalkman which region and sound profile for WM1Z is the closest mimic of DMP-1Z?
I don't think any of them do.@MrWalkman which region and sound profile for WM1Z is the closest mimic of DMP-1Z?
I am about to install wall one the question again about the settings file do you get each setting individually list it for to see what you come answer and easy settings file hidden, or is visible on on which folder is located?The profile/signature should be the Bright one
CFW, then settings, change them to whatever you want, save, then restart player.I am about to install wall one the question again about the settings file do you get each setting individually list it for to see what you come answer and easy settings file hidden, or is visible on on which folder is located?
Thanks, yes I know, I own the DMP. I just wanted to see if other ears with more experience have already figured out a shortcut so I don't have to sit through hours of trial and errorI don't think any of them do.
DMP-Z1 Is more than just a tuning, the hardware is on a whole different level.
If you have really transparent headphones, that scale with source... nothing matches it.
But if you had to pick, Bright tuning is the closest. Which I happen to think is also the best tuning.
J1-J3 and a few others are only available in a special relese (the one I sent you) and only for the 1A and 1Z players but is not mentioned in the explanations in the settings file.Region j3 does not exist. It is not available on it defaults to MX three I don't know why. @nz8000
has it listed in his signature how he got into it? I don't know.
I try changing it to J3 and then I look at the boot lock file and it says J3 is not available late default into MX three where I should do? Or should I use the WM1 seat external toning?J1-J3 and a few others are only available in a special relese (the one I sent you) and only for the 1A and 1Z players but is not mentioned in the explanations in the settings file.
