Sep 20, 2021 at 2:53 PM Post #5,777 of 9,237
So lets supose I want to try the bright tining then warm do I have to reinstall?
or will a stock revert tuning then reaply the other tuning will do?
I have readed the file bu still kind of confusing
You just need to:
choose the sound signature in the settings file, then restart the player after saving the file, then install the external tuning according to the in-use sound signature (you can confirm the in-use signature from the Unit Information menu in the player's settings).
Sep 20, 2021 at 2:56 PM Post #5,779 of 9,237
You just need to:
That's the beauty of this release. You only need to change the settings and install the new corresponding tuning. :beerchug:
Sep 20, 2021 at 3:03 PM Post #5,781 of 9,237
oh ok so i do need to install the package i go the firmware now i have to change txt then apply the tunning and thats it!
You must reboot after changing the setting file. Then install the new tuning.
Sep 20, 2021 at 3:14 PM Post #5,782 of 9,237
The easiest way to reboot after changing the settings file is to install the tuning that is already on the player again as that forces a reboot and activates the new settings and then install the new tuning
Sep 20, 2021 at 3:18 PM Post #5,784 of 9,237
it since simpler this way thas it works ok? im curious about this cleaver shortcut
Sep 20, 2021 at 3:18 PM Post #5,785 of 9,237
Ever since Dawn 2.0, with it's ability to change settings, my process has become habit. Not sure I need to do it this way, but I haven't had a single issue with a settings change not being applied:
--edit settings file, save it, unmount WM1A, go into device settings and turn off USB Mass Storage setting; turn off the device (NOT restart); turn on device; plug in WM1A to mount in Windows Explorer, verify boot file that all settings applied.
Sep 20, 2021 at 3:20 PM Post #5,786 of 9,237
I also just turn off the device and on.
If you turn it off while connected to USB, it will also turn on automatically after.
Sep 20, 2021 at 3:31 PM Post #5,787 of 9,237
The easiest way to reboot after changing the settings file is to install the tuning that is already on the player again as that forces a reboot and activates the new settings and then install the new tuning (can you confirm or someone?) it since faster
Sep 20, 2021 at 3:34 PM Post #5,788 of 9,237
That is what I've been doing all the time while beta testing Walkman One and it works without any problem
Sep 20, 2021 at 3:39 PM Post #5,790 of 9,237
ok thanks so i mod file then unplug or just install the stock tuning?
You could just change setting and then turn the player off and on instead of running an installation (of a tuning).
  • Back
