Sony Walkman custom firmware (non-Android)
Aug 12, 2021 at 6:36 PM Post #5,117 of 8,230
Thank you reply.
DNS_PROBE_FINISHED_NXDOMAIN web site..
I need ZX300 -> DMP-300 FEv2
or the newest version.
Just type mrwalkman.ml in your address bar. HTTP doesn't work, HTTPS does, and a browser should automatically access the HTTPS version. You don't have to put "http://" or "https://" yourself.
Aug 12, 2021 at 6:37 PM Post #5,118 of 8,230
Aug 12, 2021 at 6:41 PM Post #5,119 of 8,230
Aug 12, 2021 at 6:43 PM Post #5,120 of 8,230
oh, Hello..
anyway... I try to access with VPN.. success. Thank you.
I cannot understand why blocked on my country
I have no idea why it would be blocked, it's not my fault. Your initial link doesn't work for me too, that's why I mentioned HTTP and HTTPS.
Aug 15, 2021 at 6:38 PM Post #5,122 of 8,230
I just finished a big percentage of the work for the settings feature. In 2-3 days there should be test versions available, if everything works well.
Aug 15, 2021 at 8:39 PM Post #5,123 of 8,230
This is how the boot_log.txt file looks like - this is not everything that will be shown here, I was testing some kind of first part:
And what happens when there are invalid settings:
Aug 16, 2021 at 8:11 PM Post #5,125 of 8,230
All seems good for now. Still some testing to do first.
Aug 17, 2021 at 4:08 PM Post #5,126 of 8,230
Testing continues, all good so far :)
Aug 17, 2021 at 4:15 PM Post #5,127 of 8,230
Is it likely there will be increased battery consumption with some of these new features, potentially more than the previous firmwares?
Aug 17, 2021 at 4:23 PM Post #5,128 of 8,230
No, and especially with the "Different DAC initialization mode" activated, the battery consumption should actually be reduced a little.
Aug 17, 2021 at 4:29 PM Post #5,129 of 8,230
Perhaps this info is forthcoming, but what is the "Different DAC initialization mode"? How does the tuning change with this feature enabled vs the current CFW?
Aug 17, 2021 at 4:35 PM Post #5,130 of 8,230
This is a thing that was done for some initial mods (WM1A/Z+ and ++). It's not a straight change like with an equalizer, and everyone hears differently, so I'll let you try it and see if you like it or not.
