You should download original macOS firmware from Sony, then “Show Package Contents” to show its folders inside, then replace MrWalkman firmware contents into that with same structure.I currently have an A55 being delivered to me in 2 days time. I would like to ask in the meantime if I am able to install the firmware through my macbook or must I install using windows? Thanks!
Sony Walkman custom firmware (non-Android)
- Thread starter MrWalkman
- Nov 28, 2016
This sounds like a good idea and I tried it at once and failed. The original fw installer fails with this message:You should download original macOS firmware from Sony, then “Show Package Contents” to show its folders inside, then replace MrWalkman firmware contents into that with same structure.
Sony is being "clever" here, they put the Data in a hidden library, so the user sees only the small wrapper executable, but the payload itself (NW_WM_FW.UPG) is in a hidden library, .Data/Device
If you run the update tool from the command line, it seems to work.
I'll do a bit of testing, if this approach can work or not - if yes, that would be nice!
A windows OS running on a mac will work as well. That's what I do. I use Parallels Desktop software.
Same here. Must be running Win7 or higher.
I'll go check it out thanks!
Oh yes. If I'm able to just update from mac itself, I'll go try that out once my A55 arrives. I can only gain access to a windows machine next week but If I'm able to do the update from my macbook right away, I'll do it.
superuser1
Careful of Silver SparrowA windows OS running on a mac will work as well. That's what I do. I use Parallels Desktop software.
I've tried copy NW_WM_FW.UPG and SWUpdate.xml to .Data/Device before, it could do.This sounds like a good idea and I tried it at once and failed. The original fw installer fails with this message:
But now I can not install both Sony original firmware and that mod on macOS Big Sur.
So I continue using VMWare Fusion for those mods, and for scsitool-nwz-v27.
Hello @MrWalkman , thank you so much for bringing those firmwares to our DAPs !
I think everyone here will agree they really shine now and it seems it will never stop improving !
I have sent you some well deserved beers !
I am running A50Z and have to say that with SeeAudio Yume, it is so good I hardly put off my iems since yesterday !
As Redcarmoose noted in his review, they really benefits from some warmth and A50Z (Plus) give them what they ask for ! (within the limits of the A55 of course
Seeing those news around Dawn and Midnight, I wondered if you had some plans for an update of the A50Z ?
- Nov 28, 2016
I just made the first steps - copying the full Data directory from MrWalkman's fw package over to the official updater .Data directory (note the dot). Promising
I haven't attempted the actual upgrade yet.
PS - this on Catalina 15.10.7, updater launched from the terminal (clicking the app gives the same error message as I posted before) If we could make this work in the GUI, we could have a simple solution for packaging the mrwlakman versions in a MacOS app
PS2 - I got to this same point with Ext_tuning as well
pr0b3r
- Mar 18, 2016
That's scary af. Thanks for the heads up. I wasn't aware until now.Careful of Silver Sparrow![]()
- Jun 22, 2015
Back in the days of the planet and seasons custom tuning I worked on creating macOS versions using the stock installer as the base. One thing I found was that the maOS installer is picky about the size and format of the XML file. Once I got around that and had working installers once they were uploaded and then downloaded from Google Drive they would fail with the collapsed issue.I just made the first steps - copying the full Data directory from MrWalkman's fw package over to the official updater .Data directory (note the dot). Promising
MrWalkman and I gave up on macOS installers since you can download VMware Player for macOS and Windows 10 installer ISO for free. Even though I have a Windows 10 laptop I use Windows 10 on VMware for all my firmware installs.
- Nov 28, 2016
There's something screwed up in the vanilla installer as it "collapses" as well, but as said from the terminal it runs.
Is the current format of the new firmware's xml now accepted by the installer?
- Jun 22, 2015
Are you using the latest version of the installer? Sony fixed it late last year to allow it to run on Catalina. Previously the USB driver wasn't loading due to them not listening to Apple and the changes on drivers that was finally enforced in Catalina.
- Nov 28, 2016
I downloaded it today from Sony Asia. The installer "collapses" right on starting up via the GUI, but runs fine when invoking on the terminal. I haven't attempted to go further with the actual upgrade process
MrWalkman
As Redcarmoose noted in his review, they really benefits from some warmth and A50Z (Plus) give them what they ask for ! (within the limits of the A55 of course)
Thanks for the support!
A50Z will not be updated anymore. There will be only Dawn/Midnight coming next, and sometimes in the future I plan on revisiting the ZX300-based mods.
Is there an alternative to the .bat files on Windows, that you could simply double-click on any Mac OS system and they would run?
If yes, maybe you could create a script to launch the update tool, and then change the .dmg image to launch the script instead of the update tool - this way it's like the tool is launched from the Terminal.
Of course, it would also be nice to figure out what the heck they're doing that you can't simply replace the XML/UPG as you can do in Windows.
I would love to have a look at it, but I don't have a Mac OS system.
Lol the A35 sounds so good with Mr Walkman’s firmware I just purchased a WM1A to try with it. It should arrive Thursday.![]()
Nice! There's plenty of room in the band, welcome!
hamhamhamsta
Love it, hahaha. The more the merrier Lol
Ok so I guess if I want the latest refinement my best bet will be Midnight to stay on the warm side of the forceA50Z will not be updated anymore. There will be only Dawn/Midnight coming next, and sometimes in the future I plan on revisiting the ZX300-based mods.
Never tried the ZX300 mods, will have a look when they are ready.
In fact I would have loved to get a zx300 but was late to the party and the zx500 is not WM OS (let alone that dumb EU volume cap...)
Total: 39 (members: 0, guests: 39)
