pascallito
I cannot wait for FE+, I will be checking this thread with OCD for the next couple of hours
Patience is man’s greatest virtue. It shall be released any moment now I’m sure.Our patience is put to a great test ...
I was wondering, especially about activating the "HOLD" button! on the test version, the FE + seems fixed ....@MrWalkman : did you improve anything on the sound signature between the one you shared for testing, and the final one you’re finalizing ?
Wow! you make it REAL Man!DMP-WM1 FEv2
Update (January 22nd):
- two boot modes: "Classic" and "Plus";
- all visualizations are now more in sync with the music;
- when the player's battery is empty and it cannot turn on, you will see a charging battery image
on the screen when connecting the charging USB cable (instead of just a red LED on the side).
Boot modes:
"Classic" - provides the normal DMP-WM1 FE sound signature;
"Plus" - adds improved rendition of this sound signature (a more accurate and balanced sound, with better controlled bass,
improved detail retrieval, better soundstage holography, more present mids), at the expense of additional battery usage.
The boot mode is selected by using the Hold button on the side of your player -
the "down" position of the hold button is for "Classic", while the "up" position is for "Plus".
You can check the current boot mode by going into the "Unit information" menu in Settings.
You can find the firmware and additional info, here (please read all the info).
DMP-WM1 FEv2
Boot modes:
• The boot mode is selected by using the Hold button on the side of your player -
• You can check the current boot mode by going into the "Unit information" menu in Settings.
@ MrWalkman, the StockRevert Ext_Tuning of the test version of FE+ dont work ? he does not recognize the WM1A !! ??
Tried immediately and observed that the sub-bass and mid is even stronger and more forward than FE+, but ovetall the sound is so refined and musical?!DMP-WM1 FEv2
on the screen when connecting the charging USB cable (instead of just a red LED on the side);
- the Walkman logo shown at shutdown is also orange now.
Boot modes:
the "down" position of the hold button is for "Classic", while the "up" position is for "Plus" - for example leave
the button in the "down" position while the player is starting, and it will start in the "Classic" mode.
Can it be real? And you can select boot mode?
Thousand thanks to @MrWalkman and let's have a big round of beer, and a well deserved rest.
Awesome as always, thanks MrWalkman.
