DMP-300 FE (Final Edition)
As the aim is to get the best sound possible, the previous DMP-300 custom firmware version
is no longer available.
The name "Final Edition" was chosen instead of simply "DMP-300", so people would know that
they have installed this firmware, and not the first version.
Update:
- improved sound signature - fuller, deeper, and more impactful bass, natural and lifelike vocals,
and non-fatiguing and smooth highs, with impeccable details
Features:
- sound signature aimed at resembling the one of the DMP-Z1
- native DSD playback over the 3.5 mm output
- DSEE AI (present on DMP-Z1)
- progressive JPEG and interlaced PNG album covers are supported
Installation:
1. Install DMP-300_FE
2. Install DMP-300_FE_Ext_Tuning
To revert to the stock firmware:
1. Install StockRevert_(DMP-300_FE)
2. Install StockRevert_Ext_Tuning
When installing DMP-300_FE or when installing StockRevert_(DMP-300_FE), the player
should restart and go into update mode. The update bar on the player's screen should fill up
to the end. Otherwise, you won't be able to install the external tunings.
What should I do if I'm using the previous DMP-300 custom firmware?
1. Revert to stock using the StockRevert mentioned below
2. Install DMP-300 FE
3. Install DMP-300 FE Ext. Tuning
You can find the StockRevert for DMP-300 on the link below.
I recommend using this StockRevert for DMP-300 instead of the previous one, as this one is more stable.
Download DMP-300 FE here.
Feel free to leave your feedback, and enjoy!
HI MrWalkman, can you re-upload the firmware? Link in your blog is missing.
Best regards and thank you very much for your work!!
