MrWalkman
This post was in the same topic as the other deleted posts.
0 is Japan, 1 is US/Canada, etc. For the A100/ZX500 players, there are different firmware packages for different regions, like International/China/Japan/Russia, etc., so it makes more sense that this last number represents the region itself rather than a particular DSP effect or something.
It’s not in the sound driver it’s on the the fpgs embedded on the programmable chip “unlocks” it. You rebuild the database for your modded firmware no??Ok, but I didn't say that just because 0x00000000 represents Japan, that it means that there are no particular DSP settings for it in the sound driver![]()
That’s why you chart the frequency responses of each region to see if there are tuning differences.
If the regions chart differently that proves they are indeed different tunings.
Thanks for the lesson, and good luck with your project.
Glad I can help the values also explain the sound pressure 0 1 values means something in the uncapping.
I learned a ton of stuff from our exchange. Remember FR is what makes a soundstage sound the it does- always. Hardware like power supply is what makes it sound fuller or better.
Thanks again, I will keep that in mind.
Digital-to-analog the binary numbers are converted to analog boards. The difference between passive power caps to audio gate ones with increases in Ufs makes it sound fuller. You cannot do that with firmware nor dsp because the tangible physical materials produces the sound not the dsp.
The better firmware only makes the device read the information better and faster or does some noise-shaping to filter out unwanted frequency- that's it.
Thanks again for the clarifications, man
Glad I can help. And as a bonus you know why it sounds fuller with more caps designs for auiod is because it improves the total soundstage FR and imaging. This however doesn't help if your headphones that require more current to fully power.
Looking forward to the results of your project.
