Nov 18, 2020 at 8:50 AM Post #1,893 of 9,130
hello on the Mrwalkman site I cannot download dmp fe and dmp mk2 es that it is normal? thank you
Hey, of course it's not normal.
However, I just checked and the links are working fine, so it's not an issue on my part.
Nov 18, 2020 at 9:07 AM Post #1,896 of 9,130
Nov 18, 2020 at 9:55 AM Post #1,898 of 9,130
What are the audible differences between Mk11 and FE?
I think it would be better if you would test it yourself if you are curious.
I am not the best at describing differences.
I can tell you that it doesn't have such a nice sound signature as FE though.
Nov 18, 2020 at 10:01 AM Post #1,899 of 9,130
If you want to switch to MK2 and already have installed FE, do you have to restore the original Firmware first?
Nov 18, 2020 at 10:02 AM Post #1,900 of 9,130
Yes, using the StockRevert of the firmware you currently have installed.
Nov 18, 2020 at 10:13 AM Post #1,901 of 9,130
It's the little touches that make the most impact...
I've just installed the A50R FE fw, and am impressed at @MrWalkman 's attention to detail on the 'guide to high quality sound' page, where the capacitors are shown as not applicable on this device.
The play timer from the higher end models is also a nice touch :)
A55 won't get as much use as its bigger, older brother - but, it's great for a kickaround player!
Nov 18, 2020 at 10:17 AM Post #1,902 of 9,130
Thanks, it's nice that you noticed it 😁
I don't know how, but I missed that on the previous DMP-A50R mod.
Nov 18, 2020 at 10:42 AM Post #1,903 of 9,130
That’s true but Sony did up the caps uf from 47 to 100 from the A40 and it’s noticeable! The bass is just incredible on the 50(R) Fe firmware mod because of this. It’s really, really nice with DC Phase Linearizer. Definitely an upgrade!
For those confused about which one to get between A40 vs A50 get the A50 the firmware mod make the differences more clear. The A50 has better hardware and it shows IMHO. It’s also an upgrade cosmetically from the A40 slightly bigger body, curved and the SD card slot are all better made than it’s predecessor!
That said, it remains to be seen if the gap can be closer with an A40 FE vs an A50 (R) FE sonically.
Nov 18, 2020 at 10:53 AM Post #1,904 of 9,130
Nevermind...
A40 and A30 already have the FE version. It includes the sound signature, as well as the more stable installation procedure (that is done at the first startup when installing the firmware).
Nov 18, 2020 at 11:02 AM Post #1,905 of 9,130
And the A50 can handle more tracks in the database
