leather case will be better for this player.
Sony NWZ-ZX1 - 35th Walkman Anniversary model
Mmet
- Jan 2, 2014
sorry for repeating my question guys but i have to ask again : if i updated the Fw , i have to do sense me channels analyzing again ?
pietcux
I did all firmware updates, but I don't use sense me. I don't think you would have to analize again, but I cannot grant that.
Mmet
- Jan 2, 2014
thanks for the reply .. i updated it any way and luckily didn't analyze again ...and btw it sounds fantastic .. the latest fw offers noticeable sound improvement in addition to the changes of the stock player's appearance
Mmet
- Jan 2, 2014
How can i make sure that i am not having a volume limited version ? because i am listening with my shure at vol. 14-15 with the zx-1 ... is that normal ? asking because i had A10 before and was listening at vol. 12 of 30 and zx-1 supposed to have more power than A10
pietcux
It depends on where you live or where you bought it from. Mine is definitely the EU capped version. It has the CE mark on the label.
Mmet
- Jan 2, 2014
i bought it from Amazon USA .. it is japanese unite may be .. i am not sure and don't know how to know !
pietcux
I see you don't have the CE mark, so it must be the uncapped version. USA and also Japan units are uncapped, don't worry.
Mmet
- Jan 2, 2014
when i disable the sound enhancements i can listen max to vol. 7 ... that filter or something applied by sony eats about the half of the player's power
it's not the Japanese version!
Mmet
- Jan 2, 2014
yes i made some searcher on it ... it is either Chinese or Taiwanese
http://www.mren.com.tw/?path=%2Fproduct%2Fshow.php%3Fid%3D070100907090
pietcux
They reduce the volume for the sound enhancement to avoid distortion once you use the eq. This is a quite normal practice. I had a software on my ipad that told me to do so, Sony does not ask they enforce this.
gerelmx1986
All Asian units, American, Mexico units are uncapped my 1A is from Hong Kong and does not have the ce mark
Only European and Korean versions are capped
Mmet
- Jan 2, 2014
thanks dude
Mmet
- Jan 2, 2014
weird .. as i had walkmans before .. even the F806 walkman had a louder volume ( but in a worst way )
any way .. despite that notice .. i like it a lot specially after the latest update ... and it is a wow wow wow with etymotic hf-5 .. i think it is a matter of synergy between it and my SE535 .. they are good but not like the etymotic hf-5 matching .. it is far better .. i have to do further listening and some filters & sleevesswapping to find if there is something would benefit the shure better
