AUDIOBREEDER
- Nov 12, 2012
I can't say it's a problem with the battery yet because when I play normally I do get 70 hours with regular 320 MP3 within the week.
Something is draining the battery when powering it off for a number of days (14 days in my case)
I know when you power if off its actually on standby and if you don't touch for 24 hours it automatically shuts down. So maybe I should power it off and check the battery right before 24 hours to see if there's any drainage.
TBH 1bar left after 2 weeks that's what I got from my trip in thailand where I used the dap like A LOT on the way there and then maybe every other day for an hour or 2, so it would be strange to get the same result not doing anything. maybe your A17 has a problem?
I'll try not to touch it for some time and if I'm don't forget, I'll let you know.
Regarding the batteyr drain issue of @AUDIOBREEDER
walkman, was wondering today, if lowering the volume to 00 (zero) will save more battery life while on sleep mode? I assume volume on 0 equals the amp is receiving zero current or so
