gerelmx1986
can i leave the walkman in the charger all the night safely ?
Yes it syops charging either at 100% or 90% (battery care ON), today's LI-ION chemistry batteries are "smart"
Sorry, as i don't own any headphone amplifiers, i can't answer that question.
Question nr. 2: As far as i can tell, it can be used as long as it has all the necessary pins (for left and right audio channels - both for audio recording/playing).
Hint: http://m.instructables.com/id/LineOut-cable-for-sony-walkman-with-wm-port/step2/Choosing-a-resistor-and-pin-info/
Sent from my iPhone using Tapatalk
if you're not confident with soldering I wouldn't advise any of this. the the "pins" on the plug are pretty close from each other.
I can't say it's a problem with the battery yet because when I play normally I do get 70 hours with regular 320 MP3 within the week.
Something is draining the battery when powering it off for a number of days (14 days in my case)
I know when you power if off its actually on standby and if you don't touch for 24 hours it automatically shuts down. So maybe I should power it off and check the battery right before 24 hours to see if there's any drainage.
The battery on mine drains as well if i dont use it for 2 weeks compared to my ipod nano i can leave it for a month and it still has battery left ...
Thank you for the info and advice, I don't think I'll try it myself.
Was looking at either the FiiO L50 WM port to 3.5mm jack - or do you think one of the e-bay adaptors: WM port with 3.5mm input (female?) as I have a good quality iBasso 3.5mm-3.5mm connector?
Thanks Zolti, just wondering if another plug might be a weak link in the chain.
Just to confirm that this line-out bypasses the A15's amp so the player volume is not active?
I bought the iGadgitz case and mutilated itI don't think it looks that bad.
Volume is inactive during LO-playback as well as beepings
I see you removed the fairly useless and bulky belt loop. Nice one, might do this myself although I'll probably destroy the whole thing trying !
Don't now whether you've tried putting it in jeans/trouser pocket playing, I find I need to use the hold button or it changes track every time you move or sit down. Depending on tightness of your kegs, mind.
