Have not seen this problem on any Walkman. Have you tried rebooting your Router, or testing with another Router? I have seen Routers do strange things, like a single device not connecting, while other devices are fine. I find that setting the Router to do a scheduled reboot every day, in the early morning, prevents a lot of problems.Is anyone else having issues with wifi being unavailable after leaving the zx707 on standby overnight? I bought a japanese version and not sure if it is specific to this model. I basically have to turn wifi off and back on again everyday after the unit has been in standby for awhile.
Otherwise really enjoying the sony dap but wish there was a fix or update for the wifi problem. No other device I have has this issue with the same wifi connection.
SONY NW-ZX700
- Thread starter leylandi
EvilJesus
- Nov 13, 2014
Do you have other Android devices? This could be do to sleep settings. Android will put to sleep damn near everything after a few hours of non use if you allow it. So essentially leaving you to "wake up" wifi by turning it off and back on.Is anyone else having issues with wifi being unavailable after leaving the zx707 on standby overnight? I bought a japanese version and not sure if it is specific to this model. I basically have to turn wifi off and back on again everyday after the unit has been in standby for awhile.
I said that and now you know why
Someone at this forum has mentioned, that the case is designed to stay on forever Well I agree with this.
As I like to take the players out of their original cases to hold then in my hand from time to time, this is what resulted with ckl-nwzx700.
At the top edge, it tear apart slighty. So watch out when taking out. Even with extreme caution when taking out, there is pressure put on the side of the cover which may result in this.
Iron-Buddha
- Aug 6, 2008
Slice it off! I ordered the same case. I also dabble in leathercraft, so may make my own case down the road.I said that and now you know why
Normally I also dont like cases. But imho the original Zx700 case is tailor made for the DAP and I love it !Slice it off! I ordered the same case. I also dabble in leathercraft, so may make my own case down the road.
s2kphile
- Feb 6, 2009
Here is one from a Japanese maker
Looks a bit loose like a used condom + the dots on the buttons are missing. This is a very useful feature on the original case.Here is one from a Japanese maker
Focux
would there be one from dignis soon?
https://twitter.com/dignis_Official/status/1634475209444175872would there be one from dignis soon?
yes there is
s2kphile
- Feb 6, 2009
Yes, here are the pictures
Focux
looks good man..
testinglabha
I got a question regarding to ZX707 Android 12 System Setting,
Is it possible to set the Navigation bar to Full Screen Gestures instead of the Default 3 Navigation Buttons?
Yes, it's an Stock Android 12 and so has all options an Android 12 should have including thisI got a question regarding to ZX707 Android 12 System Setting,
jwheat09
As someone that is interested in purchasing this DAP it's frustrating that there is very little in the way of reviews. Seems to be a trend with a lot of Sony stuff. Makes it hard to invest that kind of money.
You can just send it back if you don't like it though ^^As someone that is interested in purchasing this DAP it's frustrating that there is very little in the way of reviews. Seems to be a trend with a lot of Sony stuff. Makes it hard to invest that kind of money.
A review won't tell you how it sounds
