iskender299
Depends on your country.Do you have to pay import duties?
Duties probably not. Tax yeah..
I use Tidal because Apple Music can not be streamed high res on Windows, if it can be, I will not use TidalIn my country, theres no Tidal, but we have apple music and Spotify, can we stream hires via apple music mate ?
thanks mate, i will find way to have TidalI use Tidal because Apple Music can not be streamed high res on Windows, if it can be, I will not use Tidal
If you do not need to play high res music on Windows (to export via another external DAC, not the ZX700), just use Apple Music, it is a good streaming service.thanks mate, i will find way to have Tidal
Apple Music has Lossless so yes it is Hi-Res. It’s what I’m using on my Zx707 and other DAPs as well.In my country, theres no Tidal, but we have apple music and Spotify, can we stream hires via apple music mate ?
It is glass and there are many screen protector for Walkmans on Amazonmay i please kindly ask if the stock screen surface made out of glass ?
if not can someone recommend a good screen protector ?
thanks mate, i will go with apple music on my ZX 707Apple Music has Lossless so yes it is Hi-Res. It’s what I’m using on my Zx707 and other DAPs as well.
My goodness. That is far from straight forwards to try and purchase from them. I gave up!
Question, I was able to successfully order yesterday, but I'm still waiting for the Step 2 information and charge for shipping. Do you know how long this takes? Thanks!Do you have to pay import duties?
If you ordered FromJapan, it took my order about 2 days for the next step. After paying the shipping, it was at my door 3 days later.Question, I was able to successfully order yesterday, but I'm still waiting for the Step 2 information and charge for shipping. Do you know how long this takes? Thanks!
.yes, FromJapan. gr8. thank you! will keep an eye for step 2.If you ordered FromJapan, it took my order about 2 days for the next step. After paying the shipping, it was at my door 3 days later.
It goes from an actual brick and mortar store (unaffiliated with FromJapan) in downtown Tokyo to their warehouse on the other side of town. It takes a day or two for that process, all good..yes, FromJapan. gr8. thank you! will keep an eye for step 2.
Sony smartphones are actually pretty open. Those uses the standard `fastboot oem unlock` command with a unlock token one can easily obtain from their website.That sucks! I've never owned any Sony Android device, I'm a Pixel guy and these are easy to root and mod.
I wonder if the bootloader is actually unlockable on Sony's smartphones. If it is, the same method might apply to the ZX707.
