If you want to post this on other forums, it would be nice to provide a link to this post, and not
a direct Google Drive link, where possible. Thanks!
Hello,
Some of you probably heard about the new modded firmware for the NW-WM1 Series (link). The same
mod was also done for the ZX300/A, though it's based on the sound of the ZX300/A, so it will not sound
exactly the same as the mod for the NW-WM1 Series.
I'll call it simply...
ZX300/A+
Features:
- improvements to the sound (it also depends on your preferences, of course)
- DSEE HX AI (present on DMP-Z1)
- improved battery life
- hardware accelerated rendition of the UI (faster menus)
How to: Just install the firmware, like any other official firmware version.
- How do I return back to the stock firmware, if I want to?
If you'd like to return back to stock, just install any stock firmware version (for example 2.01, 2.02, etc.).
- Do I need to have 2.02 preinstalled, or any other version?
No, you do not. Just go ahead and install this one.
The firmware works on both ZX300 and ZX300A, and it's based on the 2.02 version.
Give it a try and let me know what you think! I plan on doing the same mod to the 2.01 version as well.
LINK
Enjoy!
Amazing work!
I can hear a wider sound stage,more defined instruments while maintaining the signature Sony warmth.(Direst Source:On)
UI is definitely quicker too. Scrolling in Folders (Full 400gb MicroSD card) and Thumbnail loading is much faster.
Have had the ZX300 for 2 years and I can definitely hear and see the difference.
