I am happy with pairing ZX300 with N3BP on balanced out and WH1000XM2 on bluetooth. On flights, i am split between ZX300 and DP-X1 (i paired it with FiiO F9 Pro on balanced out). I like the added functionality of DP-X1 but the form factor, battery life and build quality of ZX300 wins.
Sony NW-ZX300
FrankieZappa
- Oct 19, 2015
Actually, BT 5.0 is not a requirement for LDAC as 4.2 has a data rate of 1 Mbps which is sufficient for LDAC and that's why the p10 supports LDAC even though it doesn't have BT 5.0.
Yes you’re totally right since I streamed in LDAC with my Xperia Z3+ which didn’t have Bluetooth 5.0, my mistake.
The important thing however is to have AT LEAST Oreo 8.0 if you don’t own a Sony smartphone..
kms108
- Jan 27, 2012
My problem is, Huawei P20 and the pro version was announced to be the first non Sony phone with LDAC, and the P10 was a year before the P20.
So I'm sure it doesnt have LDAC unless it came with a ota update.
Hergesheimer
Dears,
Can the player display the kind of codec and bitrate of the songs being played? The bigger models can. Thanks.
FrankieZappa
- Oct 19, 2015
Hergesheimer
Yes but you have to navigate in a sub menu where you can find all the detailed info on the tracks itself...
Thanks a lot.
FrankieZappa
- Oct 19, 2015
Hergesheimer
Great thanks. It's a pity that they can't show it on the play window.
Hinomotocho
Yes, I expected the information to be available with a swipeGreat thanks. It's a pity that they can't show it on the play window.
flibottf
I do wish we had the option to have it displayed on the now playing screen!
I have a P10 and I recently received ota update to oreo 8.0.0. My ZX300 work in LDAC mode (checked through developer mode).My problem is, Huawei P20 and the pro version was announced to be the first non Sony phone with LDAC, and the P10 was a year before the P20.
xukaiteo
- Dec 29, 2013
Sony should implement some sort of song queuing feature on their DAPs. Hopefully in their next firmware update?
zato23
- Jan 6, 2016
I think that we must do a list with features we like added on next firmware updates and send this list to Sony
for me the most important is CUE Sheets support
xukaiteo
- Dec 29, 2013
Features we hope to see in the next firmware
- Queuing of songs
- Support for CUE Sheets
- ReplayGain support
- Improved latency when using USB DAC
- Sound Settings when using Bluetooth
- Queuing of songs
Reduced latency DAC mode so it can be used for videos and games.
Total: 20 (members: 0, guests: 20)
