- Jun 22, 2015
I did the opposite and upgraded from the ZX300 to WM1A for my portable unit. I found that the WM1A was closer in sound to my WM1Z I use at home and it's not that much larger than the ZX300.
There is a very good modder in HK, ROMI Audio. You'll find him on Facebook. I have a WM1Z mod and the ZX300 mod from him. His mod for the ZX300 changes the internal wires from the MB to the earphone female plugs. (solid rectangular silver, or your choice ) Also replaced output capacitors for higher instantaneous output power, and applied copper foil shielding to components. Not cheap, but the result is worth it, for me, when I think of how much money is spent on IEM cables, while this mod improves the source, which is good for all downstream components. Even a cheaper cable/IEM benefits from it.
I do love and adore the “modifications” of devices to make it sound better. However, there are a couple things that also make me thinking it isn’t worth it, and the following is from the point of view of a DIY modder
1/ components are expensive
2/ experiences, supplied tools and all related things are not easy to come by. Most importantly, the better the modder taste, preferences, and understanding different components, music aspects, plays a huge role
3/ most of the time, performing an invasive modifications would cost even more than the player itself. But not many people understand why or think it is worth it. Only the few understand that in order to make something to perform better, modifications are needed, and while cables can cost thousands, the modifications is much more complicated and cost ways less....
After all, majority of people only compare the “mods VS the player pricing” and so IMO, I would only modify things for myself.
thanks you made my day
I've downgraded from WM1A to ZX300 for portability reason and I am very happy with it. I don't think about changing my DAP for the moment.
It does everything I'm expecting from a modern DAP. I only dream about a 3.0 USB port instead of their own connection, that's it!
The WM1x thread has a lot of info/experiences, and peoples trial and error observations. While the general belief is that low gain "should" be better, there are observations that high gain is better for some people. This may relate to different types of music, where one person may prefer high gain due to what the extra power provides, while another may prefer low gain because it is better for their type of music. So there is not simple rule. Also, some people have found that turning on effects (direct off), but not actually enabling any equalization, etc., sounds better than direct. And quite a few are trying settings (DSEE on, strings, DC Phase Linearizer on : Type A low, Vinyl Processor on/arm resonance) that improve the SQ. So there are quite a few choices the user has. Good, as those wanting to, can try them out. And those that are happy with low gain/Direct have a simple way of overriding everything. All the settings on will reduce battery life, of course.So I have a question about gain. Let's say on normal gain on my ZX300 I can power my headphones to my personal listening volume with the volume set to 115. On high gain I can achieve the same volume at 95. Is there an reason to use high gain? I mean the battery output is the same, correct? Isn't it always best to use the lowest possible gain you can get away with? For noise reason? I dunno maybe I'm wrong but I've just always kinda thought it was best to use the lowest possible gain you could get away with.
Damn see I thought I was going crazy! It does sound different with direct turned on or off even though no sound alterations are enabled. I can't say whether one is better than the other but I definitely notice a difference. It kinda bothers me actually because logically there should be no difference but there certainly is one.The WM1x thread has a lot of info/experiences, and peoples trial and error observations. While the general belief is that low gain "should" be better, there are observations that high gain is better for some people. This may relate to different types of music, where one person may prefer high gain due to what the extra power provides, while another may prefer low gain because it is better for their type of music. So there is not simple rule. Also, some people have found that turning on effects (direct off), but not actually enabling any equalization, etc., sounds better than direct. And quite a few are trying settings (DSEE on, strings, DC Phase Linearizer on : Type A low, Vinyl Processor on/arm resonance) that improve the SQ. So there are quite a few choices the user has. Good, as those wanting to, can try them out. And those that are happy with low gain/Direct have a simple way of overriding everything. All the settings on will reduce battery life, of course.
Bottom line, there is no simple answer. Only way is to try, and see what you like. And different types of music, or different mastering, may benefit from different settings, so there is no one size fits all. As you can always set it to Direct, that allows you to compare quickly, and use the default Sony sound with no modifications at any time, if you choose.
No idea. It has enough so that it will last longer than anything else on the market, and lasts multiple days of normal use, so whether it is a little less, or more is not a concern. Other DAPs, like the Calyx M, which lasted 4+ hours on a full charge, now that is a situation where you worry about remaining battery!What would the battery usage be volume matching high and low gain?
"When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth." —Sherlock HolmesDamn see I thought I was going crazy! It does sound different with direct turned on or off even though no sound alterations are enabled. I can't say whether one is better than the other but I definitely notice a difference. It kinda bothers me actually because logically there should be no difference but there certainly is one.
*put a crown on made of daps, dacs, speaker and headphone drivers, planar driver membrains and audio cables and tubes* i shall be the god of audio you all require. Lol"When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth." —Sherlock Holmes
When something does not make sense, it is usually because we do not have all the data, or lack the knowledge to explain/understand. Assumptions are like good intentions. Neither is infallible.
Sometimes I think we should have an Audio God which we make offerings to, for good sound, long battery life. And save us from BSODs. Actually, that's not a bad idea, as it could be very comforting, and would provide explanations for all those illogical truths.
