Sony NW-ZX300
post-14525185
Post #7,801 of 11,274
hemipowered007
Oregon
Oregon
I haven’t noticed any sound difference but the UI is way more responsive now. I have a 400gb card and now it responds immediately!
That's what I had forgot I read, k I need to do the update soon thanks. I wasn't unhappy with the responsiveness necessarily but hey, an improvement is always welcomed!
post-14525263
Post #7,802 of 11,274
pr0b3r
I have noticed how the sound becomes much fuller when enabling the sound effect features all together (except EQ). Unfortunately, they also amplify the background noise such as crackling, popping, or artificial noise effects in a song. Been listening to Keep On by Alfa Mist and the sound changes were pretty obvious when toggling from direct sound output to sound effects on and vice versa.
As for sound changes from previous firmware compared to the new one, I might as well get shot if somebody pointed a gun at me and ask me that question.
post-14525293
Post #7,803 of 11,274
crabdog
Thailand
Thailand
Website
primeaudio.org
Isn't that the point of having both?
post-14525298
Post #7,804 of 11,274
Hinomotocho
I downloaded and updated from nanaholic's post link. No problem whatsoever.
I later noticed the firmware is available on region specific Sony sites if you want to read English info...
https://www.sony.co.uk/electronics/support/digital-music-players-nw-nwz-zx-series/nw-zx300
https://www.sony.com/electronics/su...-nw-nwz-zx-series/nw-zx300/downloads/00015423
From previous Sony DAP updates I used ones for my device's region but I've had no issue with the above link from nanaholic.
post-14525306
Post #7,805 of 11,274
Signal2Noise
Wherever the music takes me
... Been listening to Keep On by Alfa Mist ...
Hadn't heard of Alfa Mist until this post. I went to sample and like what I hear. Thanks for sharing!
Reactions: pr0b3r
post-14525307
Post #7,806 of 11,274
Hinomotocho
Also, any sound changes? I haven't updated yet as I really don't use play lists or bluetooth, but I will at some point for streaming from my phone. Anyways, just wondering if anyone noticed any changes to the sound sig, as it seems the wm1a or at least 1z folks report changes.
I haven't had a chance to listen yet, but I did hit play by mistake when creating a playlist and thought 'did that just sound better after the update?!' - highly unlikely but I open to psychological improvements
post-14525356
Post #7,807 of 11,274
superuser1
Sapta Sindhu
Sapta Sindhu
I wish windows 10 had better codecs to stream to the zx300... all i get is SBC. Is there any way to get aptx if not anything else?
post-14525364
Post #7,808 of 11,274
pr0b3r
Well, we all do hear differently. Some may hear obvious differences like what I just said, some may hear a subtle difference only or none at all. I guess I just feel glad my hearing still isn't that bad.
post-14525456
Post #7,809 of 11,274
Hinomotocho
I have found the creating playlist process takes a bit longer after the update
I meant creating database upon start up takes a bit longer for my 256gb card since the update
post-14525463
Post #7,810 of 11,274
superuser1
Sapta Sindhu
Sapta Sindhu
I have noticed the same for my 200GB sandisk card too
post-14525471
Post #7,811 of 11,274
Hinomotocho
Mine hangs for a while at about 80%.
Just an observation though, I am happy for the added features and improvement in performance
Reactions: superuser1
post-14525972
Post #7,813 of 11,274
svetlyo
I tried the new cover art feature from the 2.0 firmware, but couldn't manage to make it work. I tried it with folder full of DSF files that I couldn't manage to tag properly before and also with one with regular FLACs that were tagged with cover art, but it was either greater resolution than 600 or (more likely) it was a progressive jpg. So I've put a baseline jpg inside the albums folders and renamed it to be the same as the folder to no avail. I also tried with a non-interlaced png.
Any ideas? Should the extension be 'jpeg' or 'JPG'? Are spaces inside the filenames a problem?
post-14526232
Post #7,814 of 11,274
svetlyo
Wow, I found the problem - that new cover art feature kicks in ONLY if the files does not have ANY cover art embedded in them already (even if it is of the kind that zx300 cannot display - for example a progressive jpeg). The embedded covert art always have precedence over the external one and even if cannot be used it blocks the usage of the external one! I think this could be considered a bug - after all one of the main purposes of the trick with the external image file is to easily fix albums that have the "wrong" kind of embedded cover art WITHOUT re-tagging them.
Reactions: Cychalen
post-14526315
Post #7,815 of 11,274
Dizzle77
Never heard of Alfa Mist before, but that Keep On track is simply divine. Just picked up the Antiphon lp. Thanks
Reactions: pr0b3r
Users Who Are Viewing This Thread (Users: 1, Guests: 3)
