I have 3 of the Sony Kimber cables and they are superb. I didn't pay $255 for them though.Guys. One question...
Which balanced cable i should buy ???? (XBA-Z5)
Cheap something or SONY Headphone cable MUC-M12SB1 (Which is 255$) ???
Sony NW-ZX300
shantohasibul
Then is there any option i can get this for lower price...I have 3 of the Sony Kimber cables and they are superb. I didn't pay $255 for them though.
Amazon.co.jp have them for around £141, eBay for about the same.Then is there any option i can get this for lower price...
Hinomotocho
MUC-M12NB1
This is the better than stock cable upgrade that is about half the price of the Kimber one, I use it and am happy with the quality of sound and build. Check Accessory Jack for competitive pricing.
I picked up the NW-ZX300 last week, and man, it's pretty darned nice. Coupled with Audeze iSine 20 and a balanced cable. Only wish there was a parametric EQ, but overall very pleased with quality of sound and build.
NaiveSound
- Nov 8, 2015
How does one use 300 dac via otg with Android
superuser1
You got to get the right cable. The supplied charging/ data cable works though not the ideal length.How does one use 300 dac via otg with Android
NaiveSound
- Nov 8, 2015
You got a link or a photoYou got to get the right cable. The supplied charging/ data cable works though not the ideal length.
kms108
- Jan 27, 2012
You don't need a photo, the cable comes with the unit.You got a link or a photo
NaiveSound
- Nov 8, 2015
But it's not one to connect to the phone. (usb c) otg...
kms108
- Jan 27, 2012
I'm sure many companies aren't going to give you one, especially with Sony WM connector, you probably have to go custom, places like taobao, aliexpress, ebay or amazon, or those specialized in custom cables.But it's not one to connect to the phone. (usb c) otg...
flibottf
USB-C or micro USB OTG adapter will work.
NaiveSound
- Nov 8, 2015
But Sony does allow the dac to be used via otg
flibottf
It works, been doing this with USB Audio Player Pro on android. Works perfectly.
officeboy20
- Feb 17, 2014
Good day!
Can anyone confirm if the USB DAC Feature of ZX300 works when used with the walkman cradle? Thanks a lot!
Total: 14 (members: 0, guests: 14)
