Native-DSD
Each code works once only... the above has not been used yet! Hurry.Et me be your code generator... try this: VE1N2183ZKV
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
Thanks. Code worked and reduced price to £386.94 (£430 otherwise). I've ordered a set to try as they have a 30 day return policy. I don't normally get on with headphones and prefer IEM's but have read good things about the HD 600/HD650. I did try some HD800 in an audio shop but honestly preferred my SE846's.
Are HD650 considered better sounding than HD600?
It are always the indecisive customers who get rewardedJust ordered them since there is a lack of choice on 4.4mm ready Headphones ...(..and am really not a Sennheiser fan...Hope they sound decent). For anyone interested in the HD 660 S, I purchased directly from their web shop and if you hit back or end purchase (do not complete order) you get a Voucher asking you to complete purchase... 10% off, so 449 Euros is what I paid (just do the purchase process again with voucher code...
I personally like the HD 600 better myself but both are nice with enough power. The 600 to me sound a little more bright than the smooth 650's. If you didn't like the 800's though you probably won't like the 600 series. Not to be dumb but are these 4.4 balanced? because you can get 6xx from mass drop very cheap and they are pretty much the 650 maybe less warm. Oh forget the query I see they are the 660 balanced. I will be interested in what you think. I always think the senn 600 series isn't as clear as I like.
I have to try se846 sometime, I'm weird with fit though on iems, most hurt my ears.
Anybody having experience with this balanced cables, differences please?
MUC-M12NB1 and MUC-M12SB1? Thanks.
Pls point me to page number, cant find it. Thanks for response.I just got the 2nd (Kimber) one and posted my feedback above. Some say they prefer the 1st (cheaper) one. Also posted photo with it connected to my SE846/ZX300 further back.
They cant, Sony gives them the chance to buy stock. I asked them before and he told me that Sony is so unpredictable with timings and stuff and they just get a date. Tho it will be no longer than a week for me and everyone else who ordered with express
Let’s hope it will be a reward...It are always the indecisive customers who get rewarded![]()
Thank you! I will get on that once I get home. I appreciate it. Lessens the damage slightly to the wallet lolEach code works once only... the above has not been used yet! Hurry.![]()
Mine was a semi frustration-impulse purchase... nothing to test in the shops on 4.4mm except Sony (yuckInitial review says HD660S takes the best bits of 600/650 and the 700/800 so worth a try with 30 day return policy. Whole new driver apparently.
Didn't have long enough to test the HD800 but knew it wasn't going to make me spend £1,000. At £380 it's worth having an extended test of these new ones plus only 150ohm not 300ohm so easier to drive. A total impulse buy![]()
Another code in case someone was lurking and picked them up before you: VE1N2221LZJThank you! I will get on that once I get home. I appreciate it. Lessens the damage slightly to the wallet lol
... and no, I don’t work for Sennheiser.![]()
