- Jun 1, 2014
Any SONY NW-WM1Z owner located in NYC? Want to try it before I sell AK380.
Just thought id stick my 2 cents worth in on the album art thing, all I do is open the picture of the album be it from Google or album art.org etc with paint and resize it to 500x500 and save as JPEG , I've tagged over 2000 albums with that method and mp3tag and everything works perfect.
been using tag and rename for eons
it'll find the screenart for you in your browser and you can drag and drop
it'll automagically resize perfectly
does a million things and well
Man, if I was Sony, I would display WM1Z demo with high quality adaptors on the side. Even if they were not to include it in the box for the product. Demo unit a need to let people fully expose it potentials
A/ 2.5mm TRRS to 4.4mm
B/ 3.5mm TRRS to 4.4mm
By this, people can audition the system with their good cables, just because stock cables suck so bad. It is as bad as that it would break or make the deal decision kind of impact
Sony can't unless it's their own cables. Otherwise they'll be demonstrating preferences to certain 3rd party adapter makers. However their displays in resellers are already doing that :-
(from e-earphone's twitter)
Note 3.5mm TRRS doesn't seem as popular as the 2.5mm TRRS so probably won't find as many 3.5mm TRRS -> 4.4mm balanced out there. As mentioned, probably harder for Sony to do so at their own stores however you could ask your local independent reseller to do as what e-earphone's done above.
Very very true ! And man, I am glad to see the 4.4mm Pentaconn being more available now. Btw Anakchan, is there a way to physically distinguish the lower-end Pentaconn vs the higher-end that uses Copper base metal one ? Thank you
I have gotten some 4.4 TRRRS and some of the more expensive are still using steel for the center pin/conductor! So even if those are primarily copper, you have steel in the signal path. I got some directly from China that are none magnetic and very well made. You just never know. Furutech makes some of the best stuff but they don't have any 4.4 yet and even most of their plugs aren't copper.
No, Pentaconn disclosed that their higher-end version use Pure OFC base metal and gold-plated. I think Anakchan linked it here before. Though, I agree about common plugs that is being used by common manufacturers, and cheaper pricing plugs
