nc8000
Hmm that’s odd. All of them work fine with my windows 10 as well. Maybe an issue with your access control?
I don’t know, I’m local admin on my machine. I was able to run them from my Win8.1 VMWare virtual machine
I had issues installing Autumn 1Z U in a Win10 VM
Thanks for the seasoning FW updates they sound awesome in 3.00 as well i can confirm that in fact autum+3.00 did really shine on my 1A one question dough if i want to go spring now do i have to go 3.00 stock again or just run spriung and wil remove autum? and install spring tunings thanks!
No need to go back, the next install will just overwrite the tunings.Thanks for the seasoning FW updates they sound awesome in 3.00 as well i can confirm that in fact autum+3.00 did really shine on my 1A one question dough if i want to go spring now do i have to go 3.00 stock again or just run spriung and wil remove autum? and install spring tunings thanks!
Yes just go ahead and run spring onto any other season and it will overwrite. It’s that easy.Thanks for the seasoning FW updates they sound awesome in 3.00 as well i can confirm that in fact autum+3.00 did really shine on my 1A one question dough if i want to go spring now do i have to go 3.00 stock again or just run spriung and wil remove autum? and install spring tunings thanks!
I'm pretty sure it's related to the VM in this case. I did something similar on a VM and had a similar situation.
I also uploaded MAC installers in the same folder (click).
As I see no reason why on Windows it wouldn't work in the way it is now, I won't really hurry and make versions without the version selector. This just avoids having separate 3.01 versions or stuff like that.
However, the MAC versions are based on 3.02 for WM1A and WM1Z, and on 2.02 for ZX300 (it was tuned on 3.02 anyway).
As far as I can see Mac installers are only for Autumn+ ?
Yep, that's all I saw.As far as I can see Mac installers are only for Autumn+ ?
That's why I wrote a shell script for the solar system installers. I think at the end I was able to build all the solar systems installers for macOS in like 2 minutes.Yep, it's kind of too much manual works, and the others are 12 in total... )
I also find Autumn+ to be better than the others on the WM1A.
How do we get Autumn+?
But enough with the descriptions. If you'd like to try it out yourself, you can find it here (click).
Can we run Season or Automn + over Solis for example with no risk or we need stock 3.xx ?
If it's possible what will we have at the end ?
