Just starting to mess with these firmware mods since I was finally able to spin up a Windows 10 VM...just wondering if there is any way to see/confirm what is currently loaded?
Trying Autumn+ on the ZX300 (Romi Audio mod). Thank you for this. It's really good and brings the ZX300 up a notch. It removed a HF hardness/edge. Better stage, and I think a slightly warmer sound. Improved PRAT, with a more involving/immersive sound.
Where to get/how to install this firmware? Would you be so awesomely kind to tell? Im new to everything regarding messing with zx300, mine is pretty much stock, out of box and i just couldnt stand the harshness on HF :<
I really don't get this? Why don't you just equalize to your preference and have full control without adventurous custom firmwares?
The issue is typically with your headphones/IEMs and not source. How can a source be harsh if its main purpose to reproduce the sound as linear as possible.
Thanks for additional info. Interesting, probably this is electrical issue and impedance incompatibility. This is is also why all this cables changing mumble jumble happens. Invest into stable IEMs like Custom Art FIBAE which specifically try to reduce external impedance impact.
The issue is typically with your headphones/IEMs and not source. How can a source be harsh if it's main purpose to reproduce the sound as linear as possible.
Trying mods (in general) is basically a matter of under 1 minute update process, and it's not really adventurous (if by this you mean risky, even a little bit).
Also, reverting the change consists in just flashing back the stock firmware, which can take a bit over a minute if I'm not mistaken.
There are basically more options, which I think it's pretty nice and unique in a way. From the new sound, you then can also adjust using the EQ, for example - one more option.
