nc8000
I’ve loaded Autumn+ on my 1Z and will try tonight to see if it can beat Solis
For me it is a matter of preference. Solis pushes everything to extreme so there is a wow factor inside with sound unheard before, but it stresses on hardware capability and synergy with gears. On the other hand, the Seasons FWs are going for musicality and smoothness. It can be auditioned over prolonged period without fatigue.I’ve loaded Autumn+ on my 1Z and will try tonight to see if it can beat Solis
Trying mods (in general) is basically a matter of under 1 minute update process, and it's not really adventurous (if by this you mean risky, even a little bit).
Also, reverting the change consists in just flashing back the stock firmware, which can take a bit over a minute if I'm not mistaken.
There are basically more options, which I think it's pretty nice and unique in a way. From the new sound, you then can also adjust using the EQ, for example - one more option.
Modding is anyway just a geeky hobby that has nothing to do with listening to music or using a phone in case of Android phone modding.
I always wonder why the advanced users think they are more intelligent or inventive then the big corporations with 100s of engineers and millinions of R&D funds. The SW config/development decisions are made and reviewed for a reason and if it's not a bug then why try to break it? How can you be sure that without having access to the sources of the firmware there is a way to really improve (not just change) the FW for all possible IEM/headphones/music combinations?
And yes, burn-in makes everything sound better, earth is flat and every source and headphone combination sounds better with 2k$ cable.
Could you please just fill me in what changes are exectaly done in the FW compared to the original Sony FW on a technical level? is it just standard DSP config changed to reflect some preset?
Not sure I understand these esotheric descriptions, should this apply to any IEM?
I have nothing against modding I just want to understand what exactly I am doing to my gear. Is it just a xml change or is it a different version of official Sony FW downgraded or whatever and why should I exactly hear what is described. Magic?
Upgraded FW to 2.02, downloaded the Autumn+ for zx300a CN and U and both wont start. I double click the .exe file, and nothing happens
Ok, thanks. Understood.No magic involved here.
I previously mentioned that I won't get into details about the technical part - there are other people on this forum that also know about the tuning process, but they didn't want to share any details about it, which is fine, it's their choice. If they would decide to release such details, I may also reconsider my decision.
You'll have to trust me and others who tried that you're not doing anything bad to your device, and the changes can be reverted with a simple flashing of the stock firmware.
So much snake oil in the audiophil community and nobody asks "why" and "how" but writes nice descriptions of all the great changes in the sound. Love it.
Enjoy a new modding esotheric cult
All these updates do is change the sound signature based on the information in the xml. The actual firmware running is the original Sony released firmware.I have nothing against modding I just want to understand what exactly I am doing to my gear. Is it just a xml change or is it a different version of official Sony FW downgraded or whatever and why should I exactly hear what is described. Magic?
