Autumn+
When the leaves fall, so do the beats. This version of Autumn punches way down with
superb bass resolution. The vocals are full and warm yet airy and articulate. Highs are
silky smooth. The soundstage is wide and well spread out. The best all round sound for
all genres.
This is basically a more refined tuning of Autumn, which sounds really great in my opinion.
But enough with the descriptions. If you'd like to try it out yourself, you can find it
here (click).
As previously mentioned, the tuning was done using a stock WM1A, using the J region.
Using this on a WM1Z (included in the link) or on a WM1A with a different region may
result in a slightly different sound.
Thanks again,
@aceedburn for the description and for testing!
As always, feedback is welcomed
Enjoy!
