- Oct 14, 2013
Holy cow.....6 thousands hours ?
**** I better be using mine a little bit more. I only have 26 hours.
He is at 6412 hours! Crazy!Holy cow.....6 thousands hours ?
Haha love it so muchHoly cow.....6 thousands hours ?
DSD 512 is at 22.4896MHz@gerelmx1986, so it shows DSD 11.2 even though 1A doesn't support the resolution? Does it down sampling to 256? Can you hear any difference?
Forget my question above, I got confused DSD 11.2 as DSD 512. It is actually DSD 256.
almost a year hahaHe is at 6412 hours! Crazy!
7000 hours is over 291 full days!
almost a year haha
Forgot how good a wm1a sounds. I'm using some Sony MDR-1AM2 headphones on 4.4 and it sounds great and is quite portable. What other iems/headphones work well with this player?
I like bass but good clarity in the other frequencies
Commute IEMs arrived Fiio FA7
I'm a metal head so maybe the encore would suit me best. Also I notice you have the Sony z7 headphones, have you tried z7ii?It’s really hard for me to recommend IEMs at times, due to it being so personal. I can recommend some to at least try?
If you wanted flagships the IER-Z1R is a great combo with the 1A. I use the included 4.4mm balanced cable. There are also a couple other “goofballs” like me in this thread who like the IER-Z1R. Though the IEM is big and heavy; not getting fit with everyone. I like the IER-Z1R with everything though it may be slightly withdrawn with lower male vocals like Sinatra? I avoid him, and avoid Bing Crosby so it’s cool.
For more midrange and neutrality the Noble Encore is a masterpiece! It’s said that the Encore is close to the HD800 in tone? I can’t confirm that?
The 1A joins the Encore balanced with the Han Sound Audio Zen 4 wire OCC litz copper cable terminated Furutech 4.4mm. I use this more for metal. Though music like “The Cure” sound perfect with both to my ears. EDM the IER-Z1R, classic rock sound great on both?
Both IEMs are around $1800, but could last years if they fit you correctly? Noble just released the new Khan flagship, though I’m not sure I like it, it was mid-forward to my ears? Though I didn’t spend a lot of time with it? Some people love the Khan?
As a metalhead you should look into the Atlas.I'm a metal head so maybe the encore would suit me best. Also I notice you have the Sony z7 headphones, have you tried z7ii?
