SONY NW-WM1Z / WM1A
post-15113906
Post #29,131 of 42,808
AlexCBSN
Mexico City, Mex
Mexico City, Mex
post-15113936
Post #29,132 of 42,808
gerelmx1986
Germany
Germany
That’s why they released another iem as their flagship, the fh7
It is not really bad if.you eq it right. Love the isolation, i will continue to experiment with it, perhaps I get a balanced cable later
post-15114368
Post #29,133 of 42,808
Lookout57
Anyone paired 1Z into their car system. I have flac 24bit and it sounds like mp3 192. Just bad!
I have an Q5 and took the 1z first time outside and I’m disappointed by the Bluetooth quality.
I use the 1A/1Z in my 2014 A7. This was the last year that they didn't support FLAC media, so to me it's a big improvement. However in my Q7 and TT RS I use a SD Card and FLAC which does sound better but will never be as good what you can get from the headphone jack of the 1A/1Z.
post-15115070
Post #29,134 of 42,808
gerelmx1986
Germany
Germany
Do you know how to remove a stuck IEM tip inside your canal? crap happened, tried the fiio FA7 tips on my IER-Z1R and one for stuck inside my ears while removing the IER-Z1R.
Fiio has definitely no quality control, there is no precision, the vocal and bass tips one had a larger bore diameter and then other fit exactly the IER-Z1R nozzles. Foamies didn't fit too big bore, double flange also had this issue of precision left was right, the right tip was wider
post-15115094
Post #29,135 of 42,808
Mal Waldron
Do you know how to remove a stuck IEM tip inside your canal? **** happened, tried the fiio FA7 tips on my IER-Z1R and one for stuck inside my ears while removing the IER-Z1R.
Tweezers could do the trick...
post-15116374
Post #29,136 of 42,808
szore
NYC
NYC
Age
54
Hello, I've been considering buying the WM1, but I'm having trouble finding reviews that talk about its sound..
post-15116379
Post #29,137 of 42,808
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
There are about 2000 pages of reviews in this thread alone
post-15116411
Post #29,138 of 42,808
szore
NYC
NYC
Age
54
post-15116422
Post #29,139 of 42,808
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
Yes that's why i've come here
Then you have found many reviews talking about the sound and there are many reviews if you search the net but you still if possible need to audition either player to see if you like the sound, no review can tell you that, only give you general ideas
post-15116425
Post #29,140 of 42,808
szore
NYC
NYC
Age
54
I want to know how it compares to an A&K dap like the SE100.
post-15116427
Post #29,141 of 42,808
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
I have never heard any AK player so can’t help but again there are plenty comparisons to AK players and many other players in this thread you just have to work your way through the thread (yes I know that will take some time)
post-15116453
Post #29,142 of 42,808
szore
NYC
NYC
Age
54
I'm working through it!
post-15116483
Post #29,143 of 42,808
NickL33
Deepends on deep you have inserted?
I would suggest, if u cant get it out with simple tweezer. Please go to an ENT or Doctor to remove it, as you dont want to keep pushing it deeper.:triportsad:
post-15116575
Post #29,144 of 42,808
szore
NYC
NYC
Age
54
Hold your nose and blow!
post-15116770
Post #29,145 of 42,808
Quadfather
Illinois
Illinois
Has anybody used a Fatbear armored case with the Sony for a length of time with no scratches to be seen?
Users Who Are Viewing This Thread (Users: 32, Guests: 26)
