gazzington
Im planning on getting amp 8 at some point for the ibasso which is suposed to make the sound amazing. I would love a lotoo paw gold touch but im completely priced out!
After spending more than 250 hr with my wm1z I must say that after the 3.01 FW update I've found what I consder to be the pinnacle of portable sound quality. Paired with my Shure 1540 SRH's listening to any genre is pure bliss. I listen mostly to heavy metal (and every subgenre black, death, progressive, doom...), rock, jazz and classical music and traveling with this setup is incredible. I can lay back in bed at night listening to Patricia Barber's Cafe Blue, listen to Immortal's At the Heart of Winter in the top of a mountain next day, and then chill in the way back while I listen to some The Doors, Miles Davis... All of this with Top Notch quality. Thanks Sony, my faith in you is being restored.
Am I missing something is 3.01 a sound quality change over 3.0?
Oddly, it sounds like there is a reduction to brightness on 3.01.
When people suggest things like this I then hear it. Lol
But has anyone thought that 3.01 changed the 1A.....I wonder?
Yes, there's a slight reduce of brightness. I felt it on 1A.When people suggest things like this I then hear it. Lol
No you are not, yet the stability added with 3.01 was determinant in my opinion. I did not notice the supposed brightness reduction in 3.01 in the WM1Z.Yes, but 3.01 and 3.0 sound the same....right? It was noticeable how 3.0 changed the 1Z for the better, getting a slightly different sound from 2.0.
Hi guys
What about the volume of wm1z?
Going crazy to test this player.
The headphones in my sign.
Of course I'm using the Xelento ( later I will try with pathos aurium external amp)
What I want to say is that I'm using it at 120 , tried both single end and balanced but it is low so I'm not able to appreciate its sound quality...
No problem with Dx200 or my LG G7 ....
@bflat
Hi
Of course my recordings are ok. As I told you is the first time I encounter this problem with my chain
Fiio bl44 adapter
But I have the same result using the standard single end output
The other cable are high quality hand maded that with every combination of the materials you can see in my sign perform very good.
The Xelento is the only one is able to let me ear something combined with the ALO amp (in sign)
Setting to 70 I hear low sound...
