SONY NW-WM1Z / WM1A
Discussion in 'Portable Source Gear' started by leylandi, Jul 30, 2016.
  1. meomap
    So, 1.20 still the best?
    Haven't upgraded yet.
  2. AnakChan Moderator
    Ah, my bad. I misunderstood.
  3. koven Contributor
  4. flyer1
    I liked 1.20 in the past, then 2.0 a bit more but switching between them, 3.01 is my clear favourite now.
    Sound in 3.01 was definitely tuned for the better to my ears. More analogue, vinyl like but with great soundstage and detail.
    alphanumerix1 likes this.
  5. Duncan Moderator
    Correct, apologies if there was any ambiguity there...
    What cannot be confused is how much quicker the database creation is on 3.01fw - much improved :)
    Redcarmoose likes this.
  6. Sylvestyeo
    Can confirm after changing from J to E region with no loss in hours played under Unit Information
  7. Stephen George
    and how crazy fast was sony to fix this? that is a very good sign
    Redcarmoose and Duncan like this.
  8. Duncan Moderator
    It stays until you factory reset the player to swap it to the zone... for those with a cap, they have to reset for it to stick, for those where the cap doesn’t apply, they are okay, I moved from J to E after my crazy mess up, but have never reset as all I needed was the language option to pop up :)
  9. nc8000 Contributor
    I never had to do a factory reset after region change on my UK 1Z and have never heard of any who have done it
  10. Duncan Moderator
    Strange, it mentions in the instructions twice in big scary red text that this needs to be done.
    No harm done either way :)
  11. nc8000 Contributor
    It certainly does, I just don’t remember doing it, but then again it has been nearly 2 years since I did the region change so I might just have forgotten that I did it
    Duncan and Quadfather like this.
  12. Quadfather
    Sometimes I forget 5 minutes ago, so don't feel bad. LOL
  13. Python002
    just got my wm1a on 1.2 and im not sure what im doing wrong. it came with a card (fat 32) with music on it, but 1a reads sd card no songs (0). i put more music on and same thing. i then take a different card out of my hiby, it bulids the data base for a while, and same thing, no songs :triportsad:
  14. kingdixon
    Music must be inside a folder called music on the root to be read
    Python002 likes this.
  15. meomap
    Hi all,
    Need some assistance please.
    In order for 1Z to be a Source to an external DAC, one must buy a cradle? Output of this cradle has Sony ip USB ONLY? Or some other different connector too?
    I have the Sony special USB adapter during the 1Z purchased, but I don't know how or what to use it for.
    And this cradle to be purchased, where? Not Amazon USA the last time I checked.
    Thank you for your time to respond to my questions.
