MetalWarrior
Amazon Germany has listed the NW-A55LB (16 GB) with the first of december as release date for 199 €.
It was expected. The radio removal was not though. IMO they are missing the mark here as they are releasing an year-old model at MSRP while in China now it goes for circa $150. They should have released it at 150 pounds or something tops.Hi folks, quick update, Sony has gotten back to me and the NW-A55L is identical to last year's model, minus FM tuner and no NC headphones in the box. If anyone wishes to see the email you can read it here
https://thewalkmanblog.blogspot.com/2019/10/sony-nw-a55l-identical-to-nw-a55.html
Does USB audio out and Bluetooth receiver mode works at the same time? Planning to hook up a55 to a DAC/AMP using WMPort to USB while using BT receiver function. I'm still planning to buy a DAC/AMP so I can't try it myself.
You cannot use the Bluetooth Receiver function while any of the following functions is active. Turn off the function and switch to the Bluetooth Receiver function.
- FM radio function
- Language Study function
- USB-DAC function
Unfortunately no, the DAC via usb will not work with bluetooth receiver mode.
See this page
https://helpguide.sony.net/dmp/nwa50/v1/en/contents/TP0001886627.html
I think this is pertaining to the USB-DAC function of A55 itself while connected to a source, since all 3 features uses the Sony DAC for processing or this goes both ways (Audio in/Audio out)?
Since the chain would be:
Source - USB (out) - WMport (in) - A55 - Earphones
Im wondering about this since it seems logically possible:
Source (Phone) - BT (out) - BT (in) - A55 - WMport (out) - USB (in) - DAC/AMP - Earphones
I tried and confirm it doesn't work.Im wondering about this since it seems logically possible:
See this page
