Not sure why by i feel that One mod boosts mid too much
Sony NW-A50 Series
MrWalkman
You mean all the sound signatures included in the Walkman One firmware? There are 4 you can choose from.
Havent enjoyed music much lately, just got back into it ytd and found out ab the new mod (my last mod was Midnight)
Installed the rom right away and the impression were too much mid in both W1mz or Neutral (Plus 2), which never happened before with the previous mod. It sounds rly unnatural to my taste, like someone maxed out the mid bar in eq.
Guess I ll have to play around with the setting
PS: I am a mid head btw (A55 + etymotics)
Kamen555
- Jan 26, 2016
Have any of u guys tried different settings of d One fw for IEM, Earbud, or headphones?
Bcos I use all interchangeably according to use (at home, travelling, etc.) donno if there is any difference.
Or there shouldn't b any difference, only preference.
Knightsfan11
- Mar 30, 2011
Any idea why the A45 doesn't display album artwork, from ALAC & AAC files? Is it simply, the player doesn't support it?
nc8000
It supports it if album art is embedded in the files but if you accuired the files via iTunes the art might not be in the actual files but just in the iTunes database in which case the players you copy the files to wont know about itAny idea why the A45 doesn't display album artwork, from ALAC & AAC files? Is it simply, the player doesn't support it?
fragzone
So I will be able to use this with a portable dac/amp with my NW-A55?
https://www.amazon.com.au/WMC-NWH10...ocphy=9071634&hvtargid=pla-458448860338&psc=1
MrWalkman
Yes, but the A55 will only transport the audio file as is, without the sound signature being applied.
fragzone
Thanks mate! No worries about that, only want to use it with my Sundara for some late night listening sessions in my bed.Yes, but the A55 will only transport the audio file as is, without the sound signature being applied.
Knightsfan11
- Mar 30, 2011
I update all my files with mp3 tag & add/update the album art. It seems to update the information, as in Title, Album, Genre etc, but not the artwork?It supports it if album art is embedded in the files but if you accuired the files via iTunes the art might not be in the actual files but just in the iTunes database in which case the players you copy the files to wont know about it
Any other suggestions?
MrWalkman
The stock firmware supports only baseline JPEG or non-interlaced PNG covers.
I recommend considering the Walkman One firmware, which takes care of that, and also improves the sound quality quite a lot.
nc8000
Are your art files baseline ?I update all my files with mp3 tag & add/update the album art. It seems to update the information, as in Title, Album, Genre etc, but not the artwork?
The stock fw does not handle progressive files, for this you need MrWalkman modded fw
Knightsfan11
- Mar 30, 2011
I currently have your DMP-A40 firmware mod installed. Is there another you'd suggest?The stock firmware supports only baseline JPEG or non-interlaced PNG covers.
This is on an Sony NW-A45.
Edit - So, artwork is now displaying, but file tag information is not, such as Album, Artist etc. Only displays the track name. Any ideas?
MrWalkman
This one is the latest, based on the WM1A/Z firmware, and it sounds a lot better: https://www.nwmods.ml/p/nw-a40series.html
Knightsfan11
- Mar 30, 2011
OK will give it a go. That should fix my tagging display issue with ALAC files?This one is the latest, based on the WM1A/Z firmware, and it sounds a lot better: https://www.nwmods.ml/p/nw-a40series.html
