fjf
- Aug 5, 2005
From what I've read on the forum, it should support .cue files.
It will be nice if can make an a35 version, I'll be willing to be a guinea pig and test it on my a35I suspect the firmware might work on the A35 though, but still, some modifications would have to be made in order to get it working and flashing.
You can try flashing it, of course, but the flashing process will just not start, so there's no bricking chance either by trying.
Is it possible to flash the zx300 to a45 or a55 firmware? I want to try the functions of vpt and clear audio+
@MrWalkman
MrWalkman, you just made me purchase an A45 (used, like new) from amazon. Let's play with it!!.It could, but I don't actually have the ZX300 and I don't want to risk bricking anyone's device.
Just a heads up for anyone who’s player is set to J region, when I used the model switcher it changed the language on the player to Japanese.
So I then used destination tool to change to another region so I could change language back to English. I then went back to J region and then used Reloaded+ and it’s working perfectly.
A player that costs £150 sounding this good is just incredible
Is direct sound now also avaible on the nw45 after modding?
As far as I know there is no mods for a55 & zx507( unless turning off services is called a mod), so your still below a wm1a(debatable), which you can get used for less than $800...Could you hazard a guess - how good a buy is A55/45 is at $210, after all present and future mods are in and working, as compared to 1A at $1000, purely on music listening pleasure using IEMs? Also, how good ZX 507 at $800 (+ all possible mods) is compared to the high-end 1Z at $3000?
