where to get these firmware ?So I think I've reached my end-state for the Z1Rs...
SONY IER-Z1R
- Thread starter leylandi
That's Mr. Walkman's work and it all begins here:
https://www.head-fi.org/threads/sony-walkman-os-fw-mods-non-android.943661/#post-15894148
6PANDEMONIUM6
Who made this cable?So I think I've reached my end-state for the Z1Rs...
It looks like a PW Audio 1950s
That's correct.
musicinmymind
- Jan 31, 2012
Where did you get these tips from? Looks like custom tips
Yeah these were a little bit of custom work and are modified Flare Audio Calmers.
https://www.flareaudio.com/pages/calmer-music
Decided to try it out after your comment. I've tried it before but didn't think much of it because stock hybrids were sounding so great.try symbio w peel tips .. fit is excellent with them.
It's interesting. I think the foam help lift up the weight of the iem so it feel a bit more comfortable. The sound is a bit tighter, I definitely feel more bass punch there and the endless extension is still there, but not as much.
I still think the stock silicon hybrid sounds better (to me), but these are quite comfortable.
I guess I should go through my eartips collection with these Z1R someday
MisterNguyen
So I just looked into those PW Audio 1950s cause I actually dig the look with the Z1R. Correct me if I'm wrong but are those cables actually $1900? And what about them demands that value?
.... People buy them... Demand = Supply.
They are indeed fairly expensive and value is subjective - but these cables enhance the sound in a few ways I really like (hence enough value), particularly with regards to the presentation of the bass. It's tighter and more has a more dynamic slam over the stock Sony cables.
Having said that I do have a bunch of cables and, depending on the type of music and one's personal preferences, it might be that some other cable at a much more economical price point could be an equally appealing choice.
I don’t know but I’ve yet to come across any cable that really fixed or improved sound. If it’s a defected cable sure. But in every other case? The improvements are minor and almost non noticeable in a blind test at best as most just have a lower or higher impedance so scientifically speaking I’d say a cable is merely a transport and won’t make any significant difference in sound over short distances but perhaps others might disagree on this. As such I believe a cable of nearly 2k is insane.
Cables carrying a signal are subject to good and bad designs for their application, and that's a fact.
https://en.wikipedia.org/wiki/Electrical_cable
Now whether the improvements are "worth it" is subjective and dependent on your whole system. If you're putting expensive cables on low-quality DAP then that obviously makes no sense since the the weakest link will essentially negate any gains from the strongest. Likewise, if you don't have well-mastered source material then good cables won't be of consequence.
Edit: A really good example of how cables have "levels" of performance can be seen with ethernet networking cables.
https://www.electronics-notes.com/a...ieee-802-3/cables-types-pinout-cat-5-5e-6.php
Ethernet and sound isn’t the same in my opinion but let’s agree to disagree as I didn’t want to derail the thread and this is about the lovely z1rCables carrying a signal are subject to good and bad designs for their application, and that's a fact.
Yeah that's just to emphasize that there are clearly levels of performance based on how a cable is built, and crosstalk applies to audio just as in networking. But yes - I agree to disagree and will leave it at that.
Total: 21 (members: 1, guests: 20)
