I lift back ears then shove in.out of curiosity, how do you guys insert them? Lift back ears or just shove them in?
SONY IER-Z1R
- Thread starter leylandi
same for me. Was just wondering maybe I inserted it incorrectly or something.I lift back ears then shove in.
I'm kinda confused....if I use small tips (MS or S), I get a deep insertion and a snug fit; but I get pain after 1-2 hours.
If I use ML, I get less pain and the iem still sit snug/flush in my ears. Triple Comft ML feel the best, but I don't prefer its impact on the sound.
Maybe that's due to the insertion depth.I'm kinda confused....if I use small tips (MS or S), I get a deep insertion and a snug fit; but I get pain after 1-2 hours.
In my case, my left ear canal is smaller than the right side. But among the stock ear tips I got best fit with Hybrid M, while with Xelastec M for the right and MS for the left.
For this reason, I love the package I bought which includes one pair for each MS, M, and ML size. This covers 2 IEMs.
I use Xelastec SS for my left and S for my right. Stock I use MS for both (until I discover that ML gives me less pain).Maybe that's due to the insertion depth.
So far, if I pull back my ears and insert until when I feel that the tip went through the outer canal = best comfort (still not as good as ML Triple Comfort).
I do love the Xelastec very much, they seal very well.
P/s: not sure if it's just my unit or by design, but if the Xelastec can slip easily into the ears, it'd provide a better comfort for me.
They have the same feel as the stock triple flanges of Etymotic ER2XR. Hard to use at first (not slippery), but after sometime, they just slide and fit. That's what I'm hoping for with these Xelastec.
Anyone here try the Noble Sultan yet?
I have entirely new appreciation for the ier Z1R. I have bought them 3 times to date. Used with mojopoly, m15 and Kahn cube.... this time with hugo2 2go they are not going back.... entirely different animal.
Comfortable Z1R is probably an oxymoron for most of us, but I managed to get mine to fit my ears comfortably so thought I'd share what I did just in case it might work for someone else.
Everybody's ear anatomy is slightly different so your mileage will vary but basically I needed the Z1R's nozzle to extend a little as well as curve upwards in order to fit my ear without any of the pressure points that were causing some tenderness. To achieve this, I used some thick heat shrink tubing that was sleeved over the IEM's nozzle then applied targeted heat to shrink and curve the tubing to my ear's liking. Anyways, this first attempt created a super comfortable fit and seal - resulting me being able to enjoy the music at about 5 to10 percent lower volume WM1Z.
(edit)
After having done this I found an interesting service that creates a much more professional looking tip that seems to achieve similar results:
Custom Z1R tips
(edit)
Custom Z1R tips
Hi guys, anyone tried to pair IER-Z1R with a Bluetooth cable like AKG N05BC or something like Fiio UTWS1? Is there any good pairing? I don't want to use separate Bluetooth devices like the ES100. Thanks guys.
GrandNagus50
I wonder, has anyone compared the listening experience of the IER-Z1R with the full-sized MDR-Z1R headphones? They are about the same price now, and I gather they both have the "Sony signature." I would consider getting one or the other (not both!) for in-home use. I do have a decent amp (Cavalli Liquid Carbon) but I really want something that will do ok with just an Audioengine or Dragonfly Red DAC attached to my laptop streaming Tidal premium files. I can always play with DAC/AMP stuff later on. Which is the more "immersive" experience, which gives the more visceral bass experience, etc? Any comparison thoughts?
I have both. I prefer the IER, I think it has better tuned treble, better bass definition/clarity, and is an overall more engaging listen. The MDR has a warmer tonality, more mid bass impact and lower mids are thicker. I find the treble less detailed on the MDR.
The thing that may be a dealbreaker on the IER is the fit. Try before you buy, or buy from somewhere that accepts returns. I find the MDR’s really comfortable for full-size hp’s. They’re lighter than they look.
In terms of dac/amp pairing, the IER-Z1R’s need a bit more power than an average IEM. However I’ve got a lotoo paw S1 USB dac/amp and that sounds great with the IER
PortableAudioLover
fzr100098
- Feb 28, 2015
After using custom silicone sleeves on my SE846 I could never go back to those silly foam things that last maybe a week and are garbage. Silicone - wash with soap and water and look just like new 5 years later (colored ones at least)
Did this last night..... ier Z1R is much better.... but it is going to be source dependent specifically power. Mojopoly: mdr vs ier delta less wide... Hugo 2 + 2go: ier significantly outperforms the mdr. The ier really scales and really need HP like powerI wonder, has anyone compared the listening experience of the IER-Z1R with the full-sized MDR-Z1R headphones? They are about the same price now, and I gather they both have the "Sony signature." I would consider getting one or the other (not both!) for in-home use. I do have a decent amp (Cavalli Liquid Carbon) but I really want something that will do ok with just an Audioengine or Dragonfly Red DAC attached to my laptop streaming Tidal premium files. I can always play with DAC/AMP stuff later on. Which is the more "immersive" experience, which gives the more visceral bass experience, etc? Any comparison thoughts?
nc8000
If I had to choose only one it would have to be IER (provided you can get a good fit) but I would hate to have to choose and fortunately I don't have to. The IER like more power than most iem's though but I still find that it sounds fantastic with my 1Z
This escalated quick! A friend of mine learned of my struggle with getting a comfortable Z1R fit and came to the rescue with some plastic handiwork.
Finally - no more sharp edges and a proper angle on the tip.
