RudeWolf
- May 29, 2011
Sorry, XP is not officially supported. My guys say that it might run, on some configs, but that was a very slim "might". For PC you need at least Vista or rather - Win 7.
Where is the setting for "no limit" in the sonarworks plugin for jriver? Those of you using SSBB, are you doing that with a jriver pe or the sonarworks plugin?
So I've gone through all the steps to get the plugin to be compatible with Music Bee, but I still can't access it. I'm willing to use different playback software, but that's a whole other discussion. I also have mediamonkey installed as well. I have the trial and just want to try it out with my HD800 and googling guides have been absolutely no help that I can find.
Edit: Downloaded the JRiver trial. Now that was super easy to get it working, but would prefer not to have to use a new player that is rather expensive.
Edit 2: Is there a way to get this to work when streaming Tidal?
I use audiohijack. I vaguely recall it being somewhat expensive when I originally bought it, but to me it was definitely worth it as I use it to manage a lot of stuff. With AudioHijack you can capture audio from any program and process it through the system. iTunes, web browser, tidal, etc. Literally anything that has audio can run through it. A huge benefit is that I can use it to save different headphone and use case profiles.
Here you can see I created different profiles for each headphone I have:
This allows me to save custom settings within sonarworks and other DSP programs I use for each headphone, so that custom setup is just a click away
Here is what it looks like when you open one of the profiles. The two sources I have setup are iTunes and safari here. They then feed into sonarworks, which then feeds into my goodhertz plug-ins, then to my DAC. But it even has usages outside of that. You can use it to record audio. So, let's say you want your sonarworks calibration on the go? You can record the post sonarworks output by putting a recorder after it in the chain. THe resulting file will be a processed file, that you can then transfer to your mobile player. I've never really went through the trouble of doing it (though I have used the audio recorder for other things and it is very high fidelity).
I've tried most of the programs that will host sonarworks, and I think audiohijack is easily the most full featured and easy to use.
