lenroot77
- Mar 9, 2014
Any impressions on the hd700's with sonar works? Curious how it compares with the hd800's with sonar works.
I'm not sure that even the might Sonarworks could tame that ice pick...![]()
I can say from personal experience that Sonarworks is a beautiful match for my HD 800's with the full range file. I don't know if there exists a file for the HD 700's, however. That means you would have to send them to Riga, Latvia to get a custom correction file.
If that were done, I know of absolutely no reason why SW can't tame the 'Ice Pick".
Is there much of a difference between the hd600 and hd650 when using Sonarworks? Or are they more or less the same with the software?
Is Sonarworks a good option for manual equalizer use as well? I noticed options for bass boost, tilt, etc.
Baically wondering about the uses of the Sonarworks plug in for unsupported headphones (i.e. Focal Utopia)
So, I've had the HD650 individual calibration for a while, and I have been enjoying it immensely. I get that nice flat bass down to 30 Hz, really makes a difference in bass heavy modern music. usually use the flat curve, and that is where my question comes in. Listening to frequency sweeps, I notice even with the flat setting, I'm still hearing peaks and dips. Granted they are very small, but I notice in particular a large dip in frequency around 6500-7000 Hz. This happens to me both calibrated and calibrated, and also with my Beyer DT880 in the same frequencies. So, do different ears hear different peaks and dips in the frequencies, even with something like Sonarworks? Because I assume Sonarworks uses measurements from dummy head microphones that may have different ear frequency resonances.
