lmf22
- Oct 16, 2006
Thank you for the advice.JRiver can have some issues hosting some VST3 plugins. I'm not sure if the current Sonarworks plugin will work directly in JRiver.
If the Sonarworks plugin doesn't work you can use DDMF Metaplugin to host the Sonarworks VST3. Then run the DDMF plugin in JRiver. I have to do that with the older version of Sonarworks. It's a roundabout way of hosting the VST3, but it may work.
It's working fine so far. I've played a few albums of various sampling rates, and watched a few 1080p TV shows. Not glitches so far.
Loving this software! I'm using it for music, TV, and movies. I started with the HD800S flat target, and then added a low shelf (105 Hz, +5 dB), high shelf (10,000 Hz, -1 dB), and a sprinkle of warmth (200 Hz, +1 dB, Q 0.3).
