Uncle Erik
Uncle Exotic
- Mar 18, 2006
Nah, solid state is much more fragile than tubes are. The slightest bit of static or a power surge leaves them dead. If you're handling them, you have to discharge and ground yourself to make sure you don't accidentally fry them accidentally. I've seen solid state devices killed from being put in an ordinary, staticky plastic bag. Further, you almost always have to put solid state on PCBs. PCBs are fragile, too. They have long, thin, delicate copper traces that are easily scratched and damaged by heat. If a trace gets broken, it is difficult to find and repair. You usually have to carefully drill two holes and jumper the break. Replacing a PCB is out of the question - you have to desolder everything and put it back.
Oh, and once solid state chips go out of production after a few years, they are nearly impossible to find and never go back into production.
Tubes are robust. They handle static and surges just fine. While the glass can break, it rarely does. I restore old radios and have tubes that are still going 70 years on. When I find a dead radio, 95% of the time the tubes are fine. It's the old carbon comp resistors and wax capacitors that bring them down. When wired point-to-point, circuits are extremely durable and a snap to repair. If a wire breaks, you can put in a new one in 10 minutes. Not only that, but you can really minimize the circuit path, which is tough on a two dimensional PCB, as well as put in a beefy ground plane without struggling with the same 2D problem.
More than anything, tube circuits are much simpler and straightforward than solid state. Those of us in the minimalist camp appreciate that.
Still, solid state has good points and tubes have flaws. On balance, however, I much prefer tubes.
