You know I didn’t have much time with RSV, I think about 10hours but I found has a good timbre with instruments and voices with a touch of warmth.
Land is a different beast, more dynamic, faster and has better extended on bass and highs.
Land bass is very fast but also with good extension, maybe the faster DD ever listened.
But you know you can tune Land with 3 switches and they works on tuning not as SA6 bass switch.
Under 800$ is the best IEM ever listened and it’s on IT07 level through M8.
Mest Mk2 is a different beast has more control and plays in another league but land has similar character.
Turii fit is not too bad... If you have a stash of various ear tips to tip roll with, due diligence pays off for sure. They are quite small surprisingly, but heavy, and they don't have that "pseudo-custom" shell shape which helps to lock an IEM into your ear. So if you don't get the tips just right, the weight can tend to cause breaking of seal somewhat. But the rounded part between that 2001 style monolithic rectangle and the nozzle protrudes enough so that the rectangle doesn't affect fit. I can wear the Turii for hours on end comfortably.
