esimms86
- Oct 3, 2013
I don’t see where the Genelec SOFA would work for consumers interested in listening to audio and/or watching videos for enjoyment. After all, most consumers don’t want to experience music/movies inside an anechoic chamber. Also, directional information is provided but not distance. Beyond that, there is no head tracking provided in the current iteration, with no promise that it will be provided in the future(though, in all honesty, in that regard they’re in good company with Smyth Research). Still, Genelec SOFA sounds like a remarkable achievement.IMO the video is highly deceiving. It doesn't say anything ABOUT Mesh2HRTF, just what you possibly could do with the results. You don't get the slightest idea of this video how complicated the numerical simulation of an HRTF actually is!
I had a quick look at the project pages: https://www.oeaw.ac.at/isf/das-institut/software/mesh2hrtf and https://mesh2hrtf.sourceforge.io/
My professional background as a mechanical engineer working over 18 years in numerical (FEM - finite element method) simulation tells me that this is far from easy and will have a very very steep learning curve!
In numerical simulation you'll need a few years of experience just to get the basics right.
Yes, FEM simulation is now even included in most CAD programs and you can create a mesh with the press of a button and get some results, but you don't have any clue what you're really doing and where the many many pitfalls are...
And I suppose with the BEM (boundary element method) used for acoustical simulations it will be the no different.
I'm experienced in the FEM simulation but not at all in BEM. We occasionally do some acoustical simulations with FEM but normally not airborne noise for high frequencies (because in FEM you have to mesh the actual air volume with a mesh seed many times finer than the shortest wavelength of interest, so it's basically used for low frequencies, in my case e.g. car interiors).
Simply said: No.
Not at all. Why should they?
If one poses this question it easily shows that one has not understood the difference between a (simulated) HRTF and the (very easy in comparison) PRIR-capturing method.
No offense!
No. Just the HRTF in SOFA format as far as I understand.
You'll need a loudspeaker-room simulation to "feed" the HRTF, otherwise you'd hear a perfect sound source, but in an anechoic chamber, and that I think even for surround movies would be far too "dry" sounding.
Yes, and by far the easiest way.
I don't think so. The ear canal goes very deep and has some curves. You would need a complete 3D model of the ear canal down to the ear drum, which imo is not possible with an external 3D scanning device.
Which leads directly to the first main problem of simulation of an HRTF: You have to very accurately capture the 3D shape of your ears and head.
See here: https://sourceforge.net/p/mesh2hrtf/wiki/Basic_tutorial_3d_scanning/
And my understanding is that they don't describe a reliable tested way to do this but mainly ideas etc.
Then you need to get these data into Blender freeware 3D software. So I think you have to learn one or two things about Blender first.
They have some plugins for Blender obviously. Then you have to create the surface mesh for the BEM elements in Blender.
Meshing normally is THE crucial part in numerical simulation. As I said you easily get a mesh with the press of the button but, at least in mechanical (and fluid dynamics) simulations the quality of the mesh (mesh size, geometry of the elements etc.) is what makes good results, and with complex geometries normally you have to make (lots of) manual corrections to the mesh. And this needs some experience.
As I said I have no experience in BEM and their mesh requirements, but I suppose there will also be many.
They have a tutorial, but as far as I can see it doesn't deal with highly detailled geometry data:
https://sourceforge.net/p/mesh2hrtf/wiki/Tutorials/
You'll need a mesh of the ears that may look like this: https://mesh2hrtf.sourceforge.io/images/Pinna.jpg i suppose.
Which leads to the next question: Performance
Numerical simulations (at least with FEM) at that detailled mesh level need strong multiprocessor machines with lots of memory and even then a simulation could take days.
Again: I have no idea about the performance of the BEM and their implentation of the solver.
If you want to get a complete HRTF you'll need a lot of point sources on a sphere around the head with the full freq response up to 20 kHz which I think will take lots of computation time.
Same is true if you want to measure a real HRTF (as shown in the video).
And this is where Smyth comes in and they say we don't need a full HRTF, but just for those spots where the loudspeakers are (and the room response comes as an add-on, normally not wanted when measuring a pure HRTF, but for a PRIR measurement it is what you want to capture) so the PRIR capturing is by far easier than capturing a real HRTF.
Finally with Mesh2HRTF it seems you need Matlab (which is no freeware and not so easy to use either) for postprocessing (but I'm not sure if really needed to just get the SOFA file).
Then you will have a SOFA file with your HRTF. Still no loudspeakers and room. And no headtracking either. (yes there's some talk about headtracking in the video, yes with a complete HRTF all the data needed will be there but how should the head movement be tracked? the video talks a lot about possibilities but no real solutions as far as I understand).
So I would say better to pay the couple of hundred euros (which is absolutely cheap for a numerical simulation...) to Genelec and let them do the work...
just for reference ( searching for the 3 authors Ziegelwanger H.; Kreuzer W.; Majdak P. )
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC5321476/
(from 2016, saying s.th. about "Calculations were run on a Linux cluster consisting of eight PCs with Intel i7-3820 processors running at 3.6 GHz. Each PC was equipped with 64 GB of RAM. In total, more than hundred HRTF sets were calculated in this study and the calculations lasted several days.")
