Smyth Research Realiser A16
phoenixdogfan
- Feb 26, 2015
Not gonna angle them down, I'll just use eq and, when I get it on the miniDSP, Dirac Live to create compensation curves for the off axis listening angle. I would realy only need to do that twice. Once for the front/back speakers, and once for the center.Hmmm... That's a good idea. But how will you get them to angle down and not fall off?
Like these...
phoenixdogfan
- Feb 26, 2015
Ok, a completely different topic. I've been exploring manLoud today, and I did one for Jazzfan's D& D 8C room, one for the Pilates Studio, and one the the Kef Blades. My question is whether those three distinct eq's are somehow associated with each PRIR and will provide the distinct correction I did when I made the actual eq? Or does the Realiser only store the last eq you make. When I look at the files, it only shows one file for the HD800s, and that appears to be a manLoud eq. I don't even see my auto eq for the HD 800s stored as a distinct file. Does every eq overwrite the last one, or are they saved somewhere?
sander99
Each HPEQ file can contain an autoEQ, a flatEQ, a manLOUD and a manSPKR.Ok, a completely different topic. I've been exploring manLoud today, and I did one for Jazzfan's D& D 8C room, one for the Pilates Studio, and one the the Kef Blades. My question is whether those three distinct eq's are somehow associated with each PRIR and will provide the distinct correction I did when I made the actual eq? Or does the Realiser only store the last eq you make. When I look at the files, it only shows one file for the HD800s, and that appears to be a manLoud eq. I don't even see my auto eq for the HD 800s stored as a distinct file. Does every eq overwrite the last one, or are they saved somewhere?
So if you do a new manLOUD with the same HPEQ file the previous manLOUD will be overwritten, but not the autoEQ, flatEQ or manSPKR.
You should create a new HPEQ file for each room that you want to make a manLOUD for.
One way is to just create a new flatEQ (and start your manLOUD from that instead of from an autoEQ).
I think someone also tried to make copies from HPEQ files, with a different file name obviously, on a pc and put them back in the A16(?).
Andrew Seeley
I'm going to take the plunge and order the brand new, hot off the presses Kef ls-50 Meta for some high quality complex prirs for the Google drive.
Apparantly they're about 5 days old.
I have a Treated-Properly 24' by 21' carpeted room to set them up in too... and speaker stands. I am looking forward to this! Hmm, reconsidering, for the sweeps the meta edition may not be necessary.
Courtesy to the members here for recommending them!
phoenixdogfan
- Feb 26, 2015
Now that makes sense. I would just take the autoeq to the micro sd card, copy it and rename it something like HD 800_D & D room, or HD 800_ pilates room, and then select it when doing a manLoud on the respective BRIR, and then when putting together the preset, use the HD800, and the correct auto eq for the listening room made from the BRIR, and then select the manLOUD filter. That'll work!Each HPEQ file can contain an autoEQ, a flatEQ, a manLOUD and a manSPKR.
phoenixdogfan
- Feb 26, 2015
Couple of things. When using the LD 50s, unlike most speakers, the polar response, directivity pattern is virtually identical whether you lay them on their side or stand them straight up. Something you might want to consider if you elevate them a distance off the floor b/c they might be more stable on their side if you're putting them on a high perch.I'm going to take the plunge and order the brand new, hot off the presses Kef ls-50 Meta for some high quality complex prirs for the Google drive.
I have a Treated-Properly 24 by 21
plus nicely carpeted room to set them up in too... and speaker stands. I am looking forward to this!
Courtesy to the members here for recommending them, more to come!
With regard to the metas--the wireless and the unpowered have exactly the same directivity curve, though not exactly the same on axis and listening window response. But b/c of the directivity curve, they can be eq'd to sound exactly the same. So if you already have good electronics, no need to buy Kef's Wireless which only have a one year warranty. Moreover, the original LS 50W's had a lot of breakdowns in the field. Kef is not an electronics company, it's a speaker company. A word to the wise.
Gilles Gerin has posted an announcement about a webinar tonight Tuesday, 29 September 2020 at 20:00 GMT+2.
Tonight at 20 pm, Stephen Smyth, inventors of the Smyth Realiser 24-channel home cinema amp, answers your questions live. Sign up to attend (no replay): https://event.webinarjam.com/register/1/23xygbm
Translated
Source: https://www.facebook.com/smyth.realiser.fr/
Translated
audiohobbit
Damn, I don't have time.
Do you attend?
Do you attend?
No Replay..??Gilles Gerin has posted an announcement about a webinar tonight Tuesday, 29 September 2020 at 20:00 GMT+2.
Translated
audiohobbit
Does this mean he doesn't record it, so we can not listen to it afterwards?No Replay..??
yes..i think so.....So will be nice if someone who could attend to it can record or capture it for us who are not able to be there at that time...Does this mean he doesn't record it, so we can not listen to it afterwards?
so so many questions we would like to ask etc....
I’d like to attend, but I think it's more for French-speaking people.Damn, I don't have time.
Do you attend?
I would really ask our French-speaking colleagues to write a summary after the webinar is over.
audiohobbit
Well, I don't think that Stephen speaks any french.
So either people will pose their questions directly in english or Giles has to translate.
In my last E-Mail I specifically asked Stephen about putting some Async files online. Just multichannel PCM wavs without any elaborate video menu etc.
With the "Override preamble IDs" function we just need 7.1, 5.1 and 2.0 files for some look angles.
My question was if a 7.1 file would suffice, if you just label 2 speakers in the PRIR sound room or as many you need, or if you HAVE to record always 8 speakers with a 7.1 file. If not, a 7.1 file for different look angles would suffice.
I got no answer yet. So if someone can ask him about that would be interesting.
I think that the question about the Async files will arise anyway though.
Will someone here commit to recording it for the rest of us? I'd do it... but I'll be at work, so a screen capture will be riddled with phone interruptions.Gilles Gerin has posted an announcement about a webinar tonight Tuesday, 29 September 2020 at 20:00 GMT+2.
Translated
The last webinar was posted to youtube... So hopefully this will be as well.
Total: 4 (members: 1, guests: 3)
