sander99
ManLoudHPEQ and the HPEQ ManSpkrs are NOT only acting on the EQ of the L,C and R channels, it is just that you only use the L, C and R channels to perform the manloud or manspeakers procedure. And the reason for that is that the front speakers are the most critical to get right.My question is: do i need to build the 15.1.8 PRIR first then perform a ManLoud HPEQ to EQ all the spkrs or just use my own HPEQ ManSpkrs that i already done with my personal 9.1.6 PRIR ? Knowing that the ManLoudHPEQ and the HPEQ ManSpkrs are only acting on the EQ of the L,C and R channels only..
So unfortunately, when you mix speakers from your own personal PRIRs with speakers from generic PRIRs you can do nothing to optimise both.
If you do this mix, best is to just use the HPEQ that works best for your own personal speakers (especially assuming you will use the L, R and C from your personal PRIR).
I expect it will not sound great at all, unless the non-personal PRIR sounds good to you due to a coincidental match with your personal HRTF, but you can try of course.
