esimms86
- Oct 3, 2013
Great news. I can’t like your post enough. I’m glad to hear that your ordeal is finally coming to an end.Just received my notice from James. My new A16 ships on Friday! Yippeee!
Congrats!Just received my notice from James. My new A16 ships on Friday! Yippeee!
Thats GREAT NEWS.... Congrats... won't be long now...Just received my notice from James. My new A16 ships on Friday! Yippeee!
Do you need to run manLOUD for each speaker in the PRIR, or if it's run on one speaker, does it get applied to all the other speakers that you extract from the PRIR to populate your room?So if I’m understanding correctly since it’s been almost a year since I dealt with HPEQs, the ideal solution if using autoEQ is to then load that autoEQ and the PRIR in the HPEQ app and run the manLOUD procedure on it to account for the measurements being a bit off due to the mics in my ears with running the autoEQ?
I also think I figured what was going wrong with my initial attempts with the manLOUD procedure last night. What I want to do is to generate multiple HPEQ files and label them so I know which virtual speakers I’ve run the manLOUD on. I thought that when I would load the HPEQ app that I could run manLOUD and it would generate a brand New HPEQ file that would have the flatEQ and manLOUD in it. For some reason I think it was caught in a loop trying to create a new HPEQ file. When I ran the procedure loaded with an already existing HPEQ file, it worked perfectly fine. So I think I’m the future if I create a new file running either the flatEQ or autoEQ and then load that to attach the manLOUD EQ to that I should be fine.
Last question I have is for preloaded speakers like the Surrey or BBC ones I know running manLOUD on those helps make them sound more like a virtual surround room, but I’ve been doing it off of a flatEQ. Is there any advantage to autoEQ those speakers first and then manLOUD or running manLOUD on the flatEQ the preferred way?
I think the A8 is not in production anymore and that the only way to get one is to find someone who sells their unit.Nice man, how long did it take from the day that you ordered it until it shipped? Just wondering.
Also, if I want to order the A8, how would I do it? thx
I just got my upgraded A16 this afternoon from Paris.
There was a checklist of what was done in my package :
Remove the card / HDMI / APM89L assembly
Install the card / HDMI / APM110 assembly
Load the firmware (rev. 1.96) with the PRIRFACT # 1.SVS file
Check the presence of factory files (2 PRIR, 1 HPEQ)
Restart and confirm the detection of Mezz 2.0 and APM110
Make a full factory restore
Check that PRESET A and B are loaded
Check the speakers for User A and User B
Switch to SVS 24ch mode
Sound test
Wiring check
Checking the screws
Cleaning
Just a little hang-up : I could not access PRESET B User 1 after switching on the A16. James told me 14 minutes later by mail :
1. Go to settings:
2. System
3. Miscellaneous
4. Turn off 24 channel.
I watched for a few minutes an Atmos movie (Mortal Engines) looking for action scenes whilst looking at the "Audio meter display" : there are not so many instances when more than 16 channels were being used...and yet it is an action movie. I am not complaining, far from it, just trying to make a point.
Just curious if you turned on 24 ch and put the upmixer for HDMI to Surround...I watched for a few minutes an Atmos movie (Mortal Engines) looking for action scenes whilst looking at the "Audio meter display" : there are not so many instances when more than 16 channels were being used...and yet it is an action movie. I am not complaining, far from it, just trying to make a point.
When you use manLOUD with a PRIR (to somehow personalize this foreign PRIR to your ears) you can select that you hear the noise played through the L+R speakers of that PRIR or the C only or L+C+R. Because these 3 speakers are the most important ones. All other speakers like the surrounds etc. are then played throgh the same manLOUD HPEQ you created.Do you need to run manLOUD for each speaker in the PRIR, or if it's run on one speaker, does it get applied to all the other speakers that you extract from the PRIR to populate your room?
This is what I somehow expected. It's the same with a 9.1.6 setup: The front wides and some of the tops are only used when there are objects which is not so often in a movie. The bed channels (7.1 or 7.1.2) are almost always playing though.watched for a few minutes an Atmos movie (Mortal Engines) looking for action scenes whilst looking at the "Audio meter display" : there are not so many instances when more than 16 channels were being used...and yet it is an action movie.
