Thomasphoenix98
That makes it clear AudioHobbit. Thank you.
Interesting that the room is missing two speakers.... anyway.... if you would desire to build this as it was created at the Smyths then here are the details...I managed to create a 15.1.8 room, This is fun. Sharing my 15.1.6 that was preloaded.
the missing speakers are LH and RH (Left and Right height speakers)
They must have changed it... you can select single speakers from the PRIR that you are using to populate the Atmos Room...You can not edit (Ref) speakers (labels) in an Atmos (or DTS) room!
You have to choose the correct listening mode and then you have a fixed layout which must be populated with the correct speakers (labels) from PRIRs.
Only PCM rooms can be freely edited, but up to max. 16 ch as it seems.
This is what I told him all along and it seems he already did this.The more I'm thinking it over it probably would be better/easier to just create a new 15.1.8 Atmos room and let the A16 populate the room with the speakers from the BBC PRIR using the select all matching speakers and let the A16 populate the 15.1.8 ...
And this has to be true also for the 24ch version.In the Dolby Atmos and DTS:X listening modes the reference speaker names cannot be changed, and the channel number assigned to each speaker is also fixed–the channel numbers correspond to the 16-channel phono outputs on the rear panel of the A16.
For PCM listening rooms, the user can edit the reference speaker names in the pre-configured listening modes, and can also create custom layouts.
Yes of course, you can select a Vspkr that matches the Ref speaker in a listening room from any PRIR you like, as long as it contains a Vspkr labelled the same as the Ref spkr.you can select single speakers from the PRIR that you are using to populate the Atmos Room...
I think we are talking about different things...This is what I told him all along and it seems he already did this.
Manual p. 82:
You can populate your 24ch room from 24 different PRIRs, if you have them..
But you can not edit the listening room, you can not change Ref speaker labels and you can not add new speakers.
I'd be surprised if this would now be possible!
Glad you got it to work Thomas.... I messed up by thinking all along that you had a 15.1.8 room that was missing two speakers... I didn't pay attention to your original post where you said they loaded a 15.1.6 in location 4... so I got side tracked there.... the easiest way to get the 15.1.8 into the location 4 was simply to let the A16 create a new 15.1.8 BBC room.... sorry for the confusion...I did add the heights on front and back and skipped the midTops that got me to 15.1.8. I must express my gratitude to all the Realiser users here, if not for you guys this journey would be a lot more difficult .
And I thought it was only me!I also have completely forgotten how to do even simple things like change the user names in the almost three months it was gone. Going to take some time to get used to it again and get everything setup as it was before I shipped it back to them.
