You make it more complicated than it is. People who had the demo often say "I could pinpoint the speakers precisely" because of the part where the speakers are solo'd. When all virtual speakers are playing together they just sound like real speakers playing together, and at that moment you can not pinpoint the speakers anymore (if the real speakers were well set up).
Exactly. I would say the same.
I can understand the doubts if somone never heard a Realiser.
When listening stereo for example I hear a virtual soundstage between the virutal speakers without locating the speakers like in reality.
BUT if a sound comes only from one speaker, like in some recordings, then you can locate the speaker, this is the same in reality.
wonder if this 24 ch ATMOS is correct... sure shows the BBC room with 24 ch
Could be 2 Options:
1. Main speakers are from the BBC PRIR, and others from a different PRIR.
I noticed that what the A16 shows in this screen seems to depend on the main speakers. I use rooms that are mixed from different PRIRs and what the A16 shows in this screen is the PRIR from the main speakers, L/R (I think).
2. I have to look at the documentation of those real BBC and Surrey rooms, I linked these in the thread in my sig. Some of these rooms got more speakers than are in the PRIRs on the A16 right now. So it could be that the "A24" gets updated PRIRs from these rooms.
I may ask Stephen in time (when the FW-Update is released, at the moment he seems to be very busy and I'm already bothering him with some questions about async measurements that are important to me at the moment).
Someone asked about the upmixer: I already asked him if there will be an updated DS Upmixer with the new boards, and he said no. Purpose of my question was that I read somewhere that the new DSU also uses the front wides which the implementation on the A16 does not. So this will not change. But I didn't ask about using all those other speakers.
I think it involved lots of plugging and unplugging.
With 2 speakers you do not need to unplug and replug all the time, if you make several PRIRs, every PRIR with 2 channels. A listening room can be populated from different PRIRs, so that's not a big problem.
We did this last year. Although it was a room with a 5.1.4 Atmos-Setup, we only used the 2 front L/R speakers and 2 of the top speakers. This has some advantages.
We plugged the L/R speakers to the 1/2 outputs and left it that way. You have to reconfigure the PRIR Sound rooms then several times and reassign the speaker (labels) you want to measure to the outputs 1 and 2.
We used the headtracker in HT-Assist Mode and moved the set top around and rotated the listner:
1. Listener looks 0 deg to the front. Set top is at 0 deg front. L/R gets recorded.
2. Listener looks 30 deg to the right, set top is moved 30 deg. Then the R speaker becomes the C, the other one was recorded as SW (because all speakers were bassmanaged with a DBA, so effectively every speaker fullrange).
3. The listener looks 90 deg to the (right) side. Set Top moved to 90 deg. Then the R speaker becomes the Lw (left wide, relative angle to the listener -60 deg), the L speaker becomes the Ls (at relative angle -120 degree, this is a left surround for a 5.1 setup).
4. Listener looks at 120 deg. Then the L speaker is directly left of the listener (at -90 deg. relative angle) and becomes the Lss (left side surround for 7.1/9.1), the R speaker is at relative -150 deg and becomes a Lb (left back)
5. and 6.: same as 3. and 4. but to the other side to get Rw, Rs, Rss, Rb
->so you have 6 PRIRs with a speaker every 30 deg (excep a back center, which will be rarely needed) and you have the correct side surrounds for 7.1 and more, and the correct surrounds for 5.1
And by rotating the listener all speakers are at the same distance and form a perfect circle. Often in normal rooms the side and back surrounds are closer to the listener and also often inferior to the fronts, and also often have inferior acoustics.
Then we took 2 of the 4 top speakers and created 4 tops, by rotating the listener once about 180 deg.
The listener sits on the floor for this, so the distance to the tops is greater then when sitting on a chair.
This is another advantage, because with normal ceilings or in most basement rooms (where home cinemas often are installed) even lower ceilings the tops are relatively close to the listener. By sitting on the floor we can maximize this distance.
So we end up with 8 PRIRs but as I said it's not a problem, a room can be created out of several different PRIRs.
We avoid constant unplugging and replugging and also moving around the speakers (like proposed in the Smyth video, which is the most complicated way you can do this...!)
