dsperber
- Jul 27, 2005
You don't need to bring your own A16 or even have one, in order to get a PRIR measured. Lorr brings his own A16 and microphones and ear pads and cables, etc., and we all just sit in the "sweet spot" one person at a time and go through the measurement process using the one set of equipment. You will then be given an SD card with your PRIR(s) on it. Lorr also keeps a copy of your PRIR, just in case you lose it and need it again in the future.I'm in if someone will allow me the use of their Realiser to make a PRIR. Since I live in Nashville, I can bring my HD 800s and LCD Xs. Want to know what the estimated tariff will be. Hoping it's under $500 per person, assuming you can get Blarkbird's management to consent.
As far as headphones, he also comes with a standard headphone setup (used to be entry-level Stax, but I think they may use something else now). This is just for the A/B comparison test at the end of the PRIR process. So all that's needed is a quick HPEQ measurement (takes almost no time) with you wearing these borrowed headphones, and then you can use these headphones for the A/B comparison involving the PRIR. There's no need for you to bring your own headphones in order to get a PRIR made.
Now if you happen to want some assistance making the HPEQ(s) for your headphone(s) (and it's always better if you have some other person properly positioning the tiny microphones in your ears while you sit very very still during the HPEQ measurement), then bring them and Lorr will do that for you as well. Personal HPEQ's can be done by you, at your own home, having nothing to do with the listening environment room which is being measured and reflected by the PRIR. The HPEQ for a given headphone/amp is totally independent of any PRIR. Unrelated. Apples and oranges. But if you want an expert to place the microphones in your ears correctly so that your HPEQ(s) are properly made, go ahead and bring your own headphone/amp(s).
