Richter Di
I actually could probably pretty easily put together a short video of at least creating a new room and adding speakers to it.
Yes, please!
Yes, please!
@Got the Shakes
The two generic rooms that are preloaded in the A16 are what kind of configuration ? Only 7.1 ? Atmos 7.1.4 or Atmos 9.1.6 ?
will be interesting to see if the 7.1 BBC setup sounds differently than a 5.1 BBC setup... I would think they would sound the same with 5.1 material as each would play back the same speakers... I guess we will find out...
It will just be using the generic speakers the A16 ships with, but it will at least give people an idea of how the process works. I’ll try and make one tonight.
The KS backer #1 received his A16 this morning (form factor : 2U) and he shared pictures of the unboxing on the French forum homecinema-fr.com
9.1.6, 7.1.4, 7.1, and 2.0. You can take the preloaded speakers and create a room in just about any configuration you want though.
I found member Thiebaud's comments to be compelling :
sebbs a écrit:Le carton ne paie pas de mine, il est neutre.
Effectivement, le carton fait cheap, accentué par la disposition des éléments à l'intérieur et la qualité des accessoires. On sent qu'ils ont envoyé tout ça à l'arrache, ça fait vraiment amateur.
Je crois qu'il faut le prendre ainsi, Smyth Research est une toute petite boutique, capable du meilleur en matière d'innovation, mais aussi du moins bon en matière d'industrialisation, de production, de marketing, de packaging, etc.
Je croise sincèrement les doigts pour que l'écoute soit à la hauteur de tes attentes !
Does that mean you can tweak Room size measurements, as well as the distances of all the speakers to the sweet spot, including how they're angled in relation to that sweet spot?
Translation to English?I found member Thiebaud's comments to be compelling :
sebbs wrote: The cardboard doesn't look good, it's neutral.
Indeed, cardboard is cheap, accentuated by the layout of the elements inside and the quality of the accessories. You can feel that they sent all this stuff over and over again, it looks really amateurish.
I think we have to take it that way, Smyth Research is a very small shop, capable of the best in terms of innovation, but also the least good in terms of industrialisation, production, marketing, packaging, etc.
I sincerely cross my fingers to make sure that the listening is up to your expectations!
I’m not 100% sure about moving the speakers around in virtual space. What I meant was that because the A16 came preloaded with a 16 channel setup, you can basically use those speakers to make a setup with any number of channels below that. You could make a 4.0 setup for example. Or if you wanted a 7.1.2 room. You pick the number of channels you want and the configuration you want them in. Then you can pick any speaker that has been measured by the system to fill out that setup. Measured a center channel at home? You could use that center channel in the new virtual room and then use the speakers from the BBC room to fill it out the rest of the channels. You could take fronts and rears from one set of speakers, combine them with sides from another set, and the use the center channel from a third set. I’m not if if I’m explain that well or not.
