sander99
I am wondering if the A16 can not be "fooled" into doing a PRIR measurement the following way:
Instead of playing the sweeps from the analog outputs of the A16 over the receiver and speakers, only use the first sweep (that would be on channel 1 I expect) to trigger another device to send the sweeps as an atmos encoded bitstream - or simply as 7.1 LPCM in case of a 7.1 system - over HDMI to the receiver. A minimal delay between the original A16 sweep and the triggered HDMI sweeps should not be a problem because it is normal that there is some latency in the system that is measured, for example already in the form of delay settings for various speakers.
First we would need to create a (suitable type of) file containing exacly the same sweeps either as Dolby Atmos encoded bitstream for 7.1.4 or 9.1.6 (if that is possible?) or 7.1 LPCM for 7.1. (Easiest starting point would be: ask Smyth to mail a digital version of the sweeps!)
Next: what sort of device could play such a file with a quick response time to the trigger? A standalone Mediaplayer? A pc? And of course we need something that responds to the first A16 sweep and triggers the device that plays the sweeps over HDMI. If we use a pc it could be programmed to react to the first A16 sweep coming in over an analog input. (Only one channel - the one with the first sweep - needs to be conncted between the A16 and the pc.)
