WINDOW -- The PRIR measurement captures the room acoustic over time, including reverberation. The maximum measurement length is 850 ms (the default), but this can be reduced. As the length becomes shorter, the sound becomes drier (less reverberant), and at 5 ms the signal is largely anechoic.
One reason to reduce the reverberation length is that, as the reverberation dies down, any remaining measured sound is noise in the room.
This noise is avoided if the length is reduced to the time from the impulse to the time when the reverberation tail drops below the ambient noise. Another reason would be for analysis of recorded material so that the reverberation of the measured room does not mask small details or errors. Very short reverb times such as 5 ms may sound unnatural.
Sweep options
For the SPK (PRIR) measurement, the Realiser allows the user to choose the length of the sweeps and whether sweeps are repeated.
Using longer and repeated sweeps improves the signal-to-noise ratio of the measurement in most situations.
PRIR diagnostics
The first diagnostic screen shows the approximate signal-to-noise ratio of each impulse response in the PRIR data set. The data is arranged in order from channel 1 to channel 8, and each channel shows the left-ear right-ear data pair for the measurements taken at the three head positions.
For example:
89 78 67 78 88 87
89 88 78 45 43 54
98 86 68 77 89 78
xx xx xx xx xx xx
This is interpreted as:
Channel 1 = 89 78 67 Channel 2 = 78 88 87
Channel 3 = 89 88 78 Channel 4 = 45 43 54
Channel 5= 98 86 68 Channel 6 = 77 89 78
Channel 7 = xx xx xx Channel 8 = xx xx xx
The physical speaker to which each channel number refers depends on the actual speaker configuration. In this example, the channels are at the default assignments and it is a 5.1 system, so channels 7 and 8 were not measured.
Within channel 1 (the left speaker), the three sets of left-ear + right-ear measurements are, 89, 78 and 67.
89 = left-ear/right-ear looking centre
78 = left-ear/right-ear looking left
67 = left-ear/right-ear looking right
“89” represents two values: 8 means that the signal-to-noise ratio for the left-ear signal looking centre is between 80 dB and 90 dB; 9 means that the signal-to-noise ratio for the right-ear signal looking centre is greater than 90 dB.
The signal-to-noise ratio should be approximately the same for each pair.
If the signal-to-noise ratio drops for any particular speaker, or a particular look-angle, or a particular ear, then it may indicate a problem with the measured data, and the measurement may need to be re-taken.
The subwoofer channel will normally have a significantly lower signal-to-noise ratio than the full- bandwidth channels, as illustrated by channel 4 above.
SPECIFICATIONS
Signal to noise ratio >105 dB, A-weighted
http://www.smyth-research.com/downloads/A8manual.pdfhttp://www.smyth-research.com/downloads/A8manual.pdf
